Butch 194 #1 Posted June 7, 2013 Can you buy the piece that holds those silver levers closed? It has the piece that goes through the lever and held there with a clevis pin. I can find drawings of the hitch and the pieces but nut the part numbers. I've been using a small machine screw with two nuts. Thanks. Share this post Link to post Share on other sites
Wishin4a416 2,610 #2 Posted June 7, 2013 (edited) Are you talking about the rear hitch for snowplow or tiller? You should be able to get at tractor supply or maybe a hardware store. Mcmaster Carr for sure but shipping would hurt on 2 small items. Like these? http://www.grainger.com/Grainger/ITW-BEE-LEITZKE-Ring-Pin-3HLK6?gclid=CKSYp5KE07cCFU6i4AodmnUARg&cm_mmc=PPC:GooglePLA-_-Fasteners-_-Pins-_-3HLK6&ci_src=17588969&ci_sku=3HLK6&ef_id=Dp9PXycj7H4AAA3K:20130607225035:s Edited June 7, 2013 by Wishin4a416 Share this post Link to post Share on other sites
baerpath 517 #3 Posted June 8, 2013 I just use a cotter key better and cheaper Share this post Link to post Share on other sites
doc724 927 #4 Posted June 8, 2013 When I bought my first plow in 1981, there were no pins (as shown by Jack in the pervious post) with the rear tach a matic. Just tighten the bolts a bit more so there is resistance when you move the levers. Make sure you have the washer BETWEEN the levers and the mounting bracket Share this post Link to post Share on other sites
Wishin4a416 2,610 #5 Posted June 8, 2013 When I bought my first plow in 1981, there were no pins (as shown by Jack in the pervious post) with the rear tach a matic. Just tighten the bolts a bit more so there is resistance when you move the levers. Make sure you have the washer BETWEEN the levers and the mounting bracket Ditto. I have two and have never had the pins. Just tighten them up good. Share this post Link to post Share on other sites
Butch 194 #6 Posted June 8, 2013 I just use a cotter key better and cheaper Would that be what I call a cotter pin and you bend one of the ends so it doesn't come out? Share this post Link to post Share on other sites
Butch 194 #7 Posted June 8, 2013 When I bought my first plow in 1981, there were no pins (as shown by Jack in the pervious post) with the rear tach a matic. Just tighten the bolts a bit more so there is resistance when you move the levers. Make sure you have the washer BETWEEN the levers and the mounting bracket Ditto. I have two and have never had the pins. Just tighten them up good. I take mine on and off often enough I just wish I could pull a pin. The way I do it now is a wrench and screwdriver. Pulling a pin would be faster and I would just leave the pins in. Share this post Link to post Share on other sites
Butch 194 #8 Posted June 8, 2013 Are you talking about the rear hitch for snowplow or tiller? You should be able to get at tractor supply or maybe a hardware store. Mcmaster Carr for sure but shipping would hurt on 2 small items. Like these? http://www.grainger.com/Grainger/ITW-BEE-LEITZKE-Ring-Pin-3HLK6?gclid=CKSYp5KE07cCFU6i4AodmnUARg&cm_mmc=PPC:GooglePLA-_-Fasteners-_-Pins-_-3HLK6&ci_src=17588969&ci_sku=3HLK6&ef_id=Dp9PXycj7H4AAA3K:20130607225035:s They're not it but they'll do. Now that I think of it I have a container of them in like 6 different sizes!! I'll have to check them out. Share this post Link to post Share on other sites
ericj 1,580 #9 Posted June 8, 2013 i believe it is a 1/4" pin i know a guy that will be at the wcc show with some of them or he could possible ship them to you if intrested pm me and i will give you his contact info eric j Share this post Link to post Share on other sites
IthacaJeff 151 #10 Posted June 8, 2013 I just use a piece of vinyl covered aluminium wire. Insert a 2" long piece and bend it around so it won't come out. Jeff Share this post Link to post Share on other sites
Tankman 3,528 #11 Posted June 9, 2013 I usually use nada, zip, nothing. The levers, snug, stay in place. Use locking nuts to avoid the bolts from workin' loose. I have used a large 1/8" Ø hair pin cotter pins in the past; easy on, easy off. 1/4" Ø clevis pins are also available at Home "Cheapo" or Lowes, off the shelf, inexpensive. http://www.zorotools.com/s/?q=.125+hairpin&1.x=8&1.y=11 Share this post Link to post Share on other sites
Butch 194 #12 Posted June 9, 2013 I usually use nada, zip, nothing. The levers, snug, stay in place. Use locking nuts to avoid the bolts from workin' loose. I have used a large 1/8" Ø hair pin cotter pins in the past; easy on, easy off. 1/4" Ø clevis pins are also available at Home "Cheapo" or Lowes, off the shelf, inexpensive. I didn't use anyn either and then the right side of my grader dropped. Share this post Link to post Share on other sites
woodchuckfarmer 333 #13 Posted June 11, 2013 I use a 1/4 inch bolt and nut Share this post Link to post Share on other sites
