WH nut
Pulled a Boner today
WH nut
I put my 8hp back together today with a new rod and piston, and did exactly what I tell everyone not to do. I didnt put the lube hole towards the cam. Ran good for about 30 minutes before she started getting tight. Have to order up a new rod again.
JimmyJam
Ouch! So it's like starting all over again? Sorry!!  & Painful!
The things we do when we get over-excited with new parts and want to fire up the engine... we get ooops-'s!!! :no:
MarkPalmer
I have adopted a process of a few double-checks before putting the oil pan on.  Piston in the right way (if directional).  Valve tappets in right positions. (Did that one wrong one time on older K where they are different lengths LOL). Timing marks aligned.  Rod cap torqued properly and in correct position. Crank end play set right.  Engine rotates without binding.
-Mark-
WH nut
The sad part is I did double check, even marked the rod so I could see it easier. I guess my eyes aint what they used to be lol. But you know the old saying, practice makes perfect. I can have to motor off annd opened up in 10 minutes. :laughing-rofl:
