redhead
Hydraulic valve
redhead
Does anyone know where i can find a diagram of hydraulic valve on c-141 wheel horse. Valve is leaking fluid from where body bolts together.
Took apart and need o-rings, have not been able to find part # for them, also their is 8 small clear gaskets, where do these go at?
Any help would be appreciated.THANKS
gwest_ca
Early manual
replaced by
Last time I checked the part numbers had changed up but still available from Toro. Check them here
http://www.partstree.com/parts/
Garry
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
