Similar Content-
			 By WheelPuke By WheelPuke
 I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
 I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
			 By Deer hunter By Deer hunter
 Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
			 By BrianStasC-101 By BrianStasC-101
 Hello all. I am looking for suggestions on adapting the pto from my C series tractor to a harbor freight predator 420 13hp engine. I know the predator motors are a controversial topic however it is the route I have chosen for this particular machine. The intent was to mostly use it for plowing so no PTO required but it would be handy to have. Looking to hear from someone that has successfully done the swap that may offer any advice before I attempt to transfer it over. Just looking for any general pointers that will help me along the way to make it go as smoothly as possible.
			 By HumbleHans By HumbleHans
 Operator manual 810343R1
 Wiring
 34 pages 17.5MB
 Wiring Colored
 1 page 228KB
 1984 C-105 8-Speed model 11-10K802
 1984 C-125 8-Speed model 11-12K802
 1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
 1984 C-165 8-Speed model 11-16K801
 1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
 1984 C-195 Twin Automatic model 01-19KE02
			 By t_furl43 By t_furl43
 1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well, it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
 92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
