gcole
K series help
gcole
Hi guys I finally got a kohler in my c-120. Now that I got it home the engine just dosnt want to run right. It spits and spudders and spits gas out the carb on rev up. But it seems to idle good lol. Anywasys if anyone has a step by step list of what to do to get her running good I would be greatly thankful
Thanks in advance. Graham
joel_400
check your timing and float level is where i would start...
joel
groundhog47
Hello Graham, you might also check this post out, sounds similar in ways and has several good "try this" advice, and it's all good advice!
Edited by groundhog47
Fordiesel69
I am batteling a bad cam, so hopefully this is not your problem.
gcole
Thanks for the replies guys. I had a chance tonight and readjusted the points as I already did today and it ran a whole lot better. With a little more carb toon I think I'll have her beat. Speaking of that how many turns out from the bottom do I turn the low and high idle and what's the smaller screw Inbetween the two?
Thanks in advance
WH nut
Thefre is no set adjustment for the carb. There is a starting point to get it running, but after that you adjust  to get her dialed in. Adjust the high speed no load is turn in until it starts to run rough, back out until it starts to run rough then turn in until she smooths out.
rmaynard
...how many turns out from the bottom do I turn the low and high idle and what's the smaller screw in between the two?
Go to section 6, page 6.4 of your Kohler manual, and you will find the initial settings for your carburetor. For the K301 it is LOW IDLE 2-1/2, HIGH IDLE 2. If you have a Walbro carburetor the only adjustment is the LOW IDLE 1-1/4 turns.
post-2221-0-46397100-1368528608_thumb.pn
If you don't have a manual you can download it from the manuals section of the forum.
http://www.wheelhorseforum.com/files/file/674-kohler-k-series-sm-tp-2379pdf/
Edited by rmaynard
gcole
Ok thank you
gcole
Well the problem is back but now it won't start at all. The first try it stuttered and quit and now it won't start at all.
Any ideas??
Thanks in advance
Fordiesel69
I will add, by posting a video of the problem will really help members pin point the problem.
gcole
Ok guys I have one more question. Would the condenser body not grounded cause the engine not to start. Mines just hanging there attached to the negative side of the coil
Thanks in advance
sorekiwi
Yes, the condenser needs to be grounded.
The fact that playing with your points gap made a difference suggests that ignition system is not where it needs to be.
gcole
Ok I'll get it grounded and see what that does for the problem
gcole
Ok guys thank you so much for the help as it is now running again. With the condenser grounded and another spark plug it fired right up
