cdsl810 181 #1 Posted May 6, 2013 While running (without lights) my battery meter is right at 12v. Turning the lights on dips to about 11v. When I use an actual multimeter, I'm getting 14v while the engine is running and about 13v with the lights on and engine running. Long story short... It doesn't seem like the charging system is doing much "charging". Should I bypass the voltage regulator and see what I measure, with the assumption that the regulator could be a little wiggly? Or, do I have nothing to worry about if the system is consistent at providing 13-14 volts? Maybe the gauge isn't what it used to be... Thanks Share this post Link to post Share on other sites
WH nut 553 #2 Posted May 6, 2013 Its working fine leave it alone and dont believe the on board gauge Share this post Link to post Share on other sites
cheesegrader 434 #3 Posted May 10, 2013 I've had problems twice where the volt meter was below 14 volts, and both prevented charging. First it was the fuse, and a year later, it was grass/crap in the fusebox. Share this post Link to post Share on other sites
