bmay432
603 trailer hitch help
bmay432
I have a 603 that I want to mount a ball on the front to pull a utility trailer. Can someone post a pic. Of what attachment I need And what it is called. Thanks
puddlejumper
A simple one to make, on both sides at the front of the tractor there will be two frame holes. The back one will be used  for the midtach plate. If you keep the midtach installed you will need a spacer plate to match the width of the bracket to the front of the tractor. Two pieces of plate drilled for a direct bolt on into those holes approx. 11/2" wide by probably 8 to 10 inches long will give you a support on each side of your tractor to build a platform to accomadate your ball. from these you can custom build/adjust the height to suit yourself.
bmay432
thanks puddle jumper
