TheeNickster 0 #1 Posted April 24, 2013 Hello Everyone, I just picked up a '90 416-8 a couple weeks ago. I am suspecting my voltage regulator has gone south. I was trying to pull the flywheel cover off and removed the obvious bolts on the sides, and one on the bottom. I noticed the choke cable assembly is also attached. With all those bolts removed, the cover still seems to fastened tight. I was just curious if there are other fasteners elsewhere that I may have missed. Just figured I'd make my first post on here before I got carried away and started tearing stuff off that I didn't really have to. Glad to be a new member, and thanks in advance for any pointers. Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted April 24, 2013 There are some bolts aroung the coil Share this post Link to post Share on other sites
dbartlett1958 99 #3 Posted April 24, 2013 Just wondering why you want to remove the flywheel cover to replace the regulator. It is easily accessible. Share this post Link to post Share on other sites
JackC 619 #4 Posted April 24, 2013 Voltage regulator sits on top of the engine tin at the back of the engine. Share this post Link to post Share on other sites
varosd 1,185 #5 Posted April 24, 2013 Do you mean the ignition control module?, which is indeed behind the flywheel. Share this post Link to post Share on other sites
TheeNickster 0 #6 Posted April 24, 2013 Well damner...I had the two backwards. Thanks fellas!!!! Share this post Link to post Share on other sites
