Big Jake 18 #1 Posted April 13, 2013 I pick up a Ford lgt165 the owner said the head was bad. He was right it had a hole burnt thru it. The plston, valves and block look good could it be a to lean or a faltie head Jake Share this post Link to post Share on other sites
WH nut 553 #2 Posted April 13, 2013 I pick up a Ford lgt165 the owner said the head was bad. He was right it had a hole burnt thru it. The plston, valves and block look good could it be a to lean or a faltie head Jake What did the top of the piston look like, if its chalking its lean. Could have been inproper torgue or it got hot. Share this post Link to post Share on other sites
Big Jake 18 #3 Posted April 13, 2013 The piston was black in color with light carbon. That way I thought maybe bad head (sand hole) Share this post Link to post Share on other sites
WH nut 553 #4 Posted April 13, 2013 The piston was black in color with light carbon. That way I thought maybe bad head (sand hole) Clean her up, make sure the head is flat and run her Share this post Link to post Share on other sites
Fordiesel69 274 #5 Posted April 15, 2013 If it was lean the EX valve will burn. We burned one up on a K181 having it too lean. Share this post Link to post Share on other sites
