Wheelhorse84 87 #1 Posted April 4, 2013 So I need to replace my center spindle in my 42 inch side discharge deck. The threads where the blade bolts on are severly damaged by the previous owner. I call to get a price from my local dealer 200 and some odd dollars. Thats alot of money. He said it came with the double pully also. Any cheaper alteratives? The decks model # is 78345 Thanks Share this post Link to post Share on other sites
WH854 45 #2 Posted April 4, 2013 So I need to replace my center spindle in my 42 inch side discharge deck. The threads where the blade bolts on are severly damaged by the previous owner. I call to get a price from my local dealer 200 and some odd dollars. Thats alot of money. He said it came with the double pully also. Any cheaper alteratives? The decks model # is 78345 Thanks Yes you can replace the spindle shaft only. Chas Share this post Link to post Share on other sites
Wheelhorse84 87 #3 Posted April 4, 2013 Is it hard to do? Never done one before. Share this post Link to post Share on other sites
WH854 45 #4 Posted April 4, 2013 Is it hard to do? Never done one before. Was not hard for me are you machinelly inclined? Chas Share this post Link to post Share on other sites
WH854 45 #5 Posted April 4, 2013 Put your Model# here will give you a break down of your deck https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Chas Share this post Link to post Share on other sites
groundhog47 432 #6 Posted April 4, 2013 Are your spindle shafts approx. 5/8" dia, metric bearings, 3/4" blade end, non keyed, and an o ring between bearing and pulley or 3/4" keyed, parts shows first. Anyway classified add expired and have 3 of ist (used), center pulley also and 1 of 2nd (NOS). pic of first follows: So I need to replace my center spindle in my 42 inch side discharge deck. The threads where the blade bolts on are severly damaged by the previous owner. I call to get a price from my local dealer 200 and some odd dollars. Thats alot of money. He said it came with the double pully also. Any cheaper alteratives? The decks model # is 78345 Thanks Share this post Link to post Share on other sites
Forest Road 595 #7 Posted April 4, 2013 I have 3 used spindles available. PM me for more info. Share this post Link to post Share on other sites
Tim 97 #8 Posted April 4, 2013 i think i have a couple spindles hanging around if interested come pick it up if you bring the deck over i'll show you what to do i'm only 15 minutes from the mendon drive in let me know Share this post Link to post Share on other sites
