Thehunter 9 #51 Posted April 11, 2013 since I'm not using the right hand side mower clutch pedal, I drew up a spacer to slide on the foot pedal cross bar to fill in that gap and keep everying at the same diameter. my buddy is making it now. here's an action shot... this spacer will go here and be secured by a set screw Share this post Link to post Share on other sites
Thehunter 9 #52 Posted April 12, 2013 got it fit up last night, now it just needs paint... Share this post Link to post Share on other sites
faster 11 #53 Posted April 14, 2013 Great job. Keep the pictures coming. Share this post Link to post Share on other sites
welderman85 53 #54 Posted April 14, 2013 Great work Share this post Link to post Share on other sites
Thehunter 9 #55 Posted April 15, 2013 hi all, made some progress this week. Got a set of thumb screws and installed the battery bracket... I did alot of sand blasting, and got some more red on her, I now have a dedicated "paint tree"... Next, i turned my attention towards the front wheels. They had a few bends in the lip, so I made a tool with the correct radius to align them. I used a propane torch to apply heat and whacked em good with a hammer. I primed the front wheels, and painted the barrels with gloss almond. Note that when washing them after blasting, you can push water inside the barrels thru the joined opening where the arrow is. I turned the holes facing 12 and 6 oclock and heated the wheels with a large propane venturi torch to force dry them. here are the 2 fronts after painting the barrels... Share this post Link to post Share on other sites
Thehunter 9 #56 Posted April 16, 2013 picked some fruit off the "paint tree" after letting it dry for 30hrs. and how she sits now... Share this post Link to post Share on other sites
xenon213 10 #58 Posted April 16, 2013 Looks great ! :) Share this post Link to post Share on other sites
Thehunter 9 #59 Posted April 16, 2013 thanks guys! appreciate it Share this post Link to post Share on other sites
Thehunter 9 #60 Posted April 17, 2013 next I looked at the steering spindles. They have the c-clip at the ends, and i wanted to add a tapped hole in the ends to better secure the front wheels. I fitted up 2 new wheel bearings in one fo the front wheels, and fit it to the axle. I had about an extra 1/2" sticking out since the new bearings had a thinner flange thickness than the stock aluminum bushings. I plan to shave off 3/8th's from the ends. But first I decided to tap holes in the end. I found out my drill press platen had a 3/4" hole drilled in it, which was the same diameter as the spindle shaft (how convenient). so I chucked up a 3/4" wood bit and aligned it to the hole. Now the drill arbor was perfectly aligned to the centerline of the spindle. I drilled a 3/4" hole thru a piece of wood to give the spindle more surface area to align against, and realigned the chucked up bit to both thru holes. I went slow and used lots of cutting fluid, worked like a charm Share this post Link to post Share on other sites
Thehunter 9 #61 Posted April 18, 2013 Last night I shaved off 3/8" inch from the end of the spindles, and tapped/chamfered the holes. ahhh, much better Share this post Link to post Share on other sites
Thehunter 9 #62 Posted April 23, 2013 over the weekend i primed all 4 rear rims (going duallie!) .... and I mounted the front tires (tri ribs) and installed the front end. Share this post Link to post Share on other sites
zipper 10 #63 Posted April 26, 2013 Dang, just love your paint tree. I like the idea of a Mass get togther, please keep me informed. i am doing a 1976 C-120. Your doing an awsome job. Share this post Link to post Share on other sites
Stigian 1,235 #64 Posted April 28, 2013 Some great fabrication going on there, the rear chassis repair is really neat.. Your doing a 1st class job, keep them photo's coming Share this post Link to post Share on other sites
Kruppk63 0 #65 Posted May 2, 2013 Hi, what is a e tank and how do you make it? Share this post Link to post Share on other sites
fireman 1,022 #66 Posted May 2, 2013 Steve, is that the tractor we changed out the steering tower on in the back yard of your old house? If so I remember that. We made it from two parts tractors and a bunch of spare parts! Share this post Link to post Share on other sites
Thehunter 9 #67 Posted May 7, 2013 Hi all, finally got my K161 back from the machine shop. it's looks nice and shiny. Had the bore done, valve seats recut, new valve guides, and fly cut the head. nice crosshatch 1 Share this post Link to post Share on other sites
Jake Kuhn 1,600 #68 Posted May 8, 2013 Very nice! Too bad you can't just leave it that color! Share this post Link to post Share on other sites
raider10-8 9 #69 Posted May 8, 2013 looks great. ive been watching the post or a while now and just wanted to say your doing GREAT work!! keep the pics comming Share this post Link to post Share on other sites
Thehunter 9 #70 Posted May 17, 2013 hi all, haven't posted in a little while, been busy with work etc... I have a 3d printer at work, so I played around today with a custom "702" cap for the front wheels. I think it looks pretty cool, now just need to print it in "wheel horse red". Share this post Link to post Share on other sites
953 nut 70,086 #71 Posted May 18, 2013 since I'm not using the right hand side mower clutch pedal, I drew up a spacer to slide on the foot pedal cross bar to fill in that gap and keep everying at the same diameter. my buddy is making it now. here's an action shot... this spacer will go here and be secured by a set screw So good to have a buddy who can turn out custom parts like that, need to buy him a steak! hi all, haven't posted in a little while, been busy with work etc... I have a 3d printer at work, so I played around today with a custom "702" cap for the front wheels. I think it looks pretty cool, now just need to print it in "wheel horse red". You have some KOOL toy to play with. This is a good series of updates you have been giving us, and you are doing a great job. Share this post Link to post Share on other sites
Thehunter 9 #72 Posted May 22, 2013 progress has been slow, lots of other stuff going on... I got the tranny etanked, walnut shelled, and primed. hopefully I can get a lot of stuff sorted over the long holiday weekend. I'm also restoring an antique pull wagon for a good friend that is having his first baby, those are two of the wheels shown alongside the tranny halves. I'm going to paint the wagon wheel horse red with antique white wheels. Share this post Link to post Share on other sites
Thehunter 9 #73 Posted May 29, 2013 Hi all, got the tranny halves prepped, primed, and painted finally, they came out pretty nice. got the front end banjo bolts painted along with the stop bracket. I snapped the first cast iron spindle link, luckily Dave (gumshoes) had a spare... thanks Dave. So I painted that up and finally assembled the front steering linkage. also finished painting all the wagon parts that I'm restoring in wheel horse red and antique ivory. still working on the tub but the other parts came out beautiful.... Share this post Link to post Share on other sites
Tonyp 285 #74 Posted June 3, 2013 one word ... NICE ! Share this post Link to post Share on other sites
gumshoes 205 #75 Posted June 3, 2013 Your doing good rookie. Your making us old timers look bad. Keep up the great work Share this post Link to post Share on other sites
