chris11 184 #1 Posted March 15, 2013 does anyone need any tran bearings? Share this post Link to post Share on other sites
VinsRJ 724 #2 Posted March 15, 2013 (edited) Standard R12 open bearings... any bearing place, Ebay or Amazon... I find Ebay and Amazon to be the cheapest... they all originate from Cheena any-how. I even get the bushing from Ebay or Amazon too. Edited March 15, 2013 by VinsRJ Share this post Link to post Share on other sites
rmaynard 17,634 #3 Posted March 15, 2013 Do you have bearings for sale Chris? Share this post Link to post Share on other sites
chris11 184 #4 Posted March 15, 2013 I have a guy making them up 9.00 each min of 10, i just ordered some. Share this post Link to post Share on other sites
mdclem 12 #5 Posted March 15, 2013 I got all my bearings (bronze and ball) from motion industries. they had everything to completely rebuild my trans for about $80. Even found the 3/8" thick ball bearings. Share this post Link to post Share on other sites
HENRYG 36 #6 Posted March 20, 2013 Hey Chris do you have any 1503 axel bearings for my rj need two thanks HenryG. Share this post Link to post Share on other sites
stevasaurus 23,860 #7 Posted March 20, 2013 Henry, if Chris does not have those parts (1503)...Motion Industries has them for about $2.50 apiece...use # CB1618-12 Bronze Bearings. Share this post Link to post Share on other sites
HENRYG 36 #8 Posted March 20, 2013 Thanks Steve appreciate the number and the help. Share this post Link to post Share on other sites
buckrancher 2,697 #9 Posted March 20, 2013 here an little tip for all the RJ58/59 guy's The R12 bearings are a tight tolerance bearing they are not disigned to be use in all bearing positions in a RJ transmission as the RJ trans case's are not pinned inalinement to each other that is why the 3/8" wide unground bearings are used as they have a large tolerance and can handle the miss alinement in the 5003/5010 transmissions. you can get the unground bearings from mcmaster-carr for around $6.00 each the last time I checked why I'm telling to this is if you are going to put a higher strain on the transmission (smaller pullys,bigger motor etc.)you may want to stay with the standard bearings in there correct positions but if all your going to do with the tractor is ride around at a tractor show or pull a small wagon you can probably get away with the R12's they just are not going to last as long as the unground bearings will Brian Share this post Link to post Share on other sites
chris11 184 #10 Posted March 24, 2013 The unground bearings are the ones im getting. I may not run the tran on the hot rod one. maybe just a staight axle with chain drive to clutch Share this post Link to post Share on other sites
