tommyg
Trickle charge a D
tommyg
Does anyone know if it's OK to put a trickle charge (or any charge for that matter) on a D battery without disconnecting the ground or anything? I have this sticker on mine that says not to weld on the tractor without disconnecting something or other, but I don't know if that applies to charging. Just wondering.
bitten
Yes you can charge the battery with it hooked up.
The only thing I can think of that would hamper charging it hooked up would be if there is something on the tractor that is pulling juice when the tractor key is in the off position. Not really that it would hamper it as much as there is something wrong that would need fixed.
tommyg
Thanks. Any idea why welding without disconnecting the regulator would be an issue?
wheeledhorseman
Electrical welding can create damage to electronic components and there are some in the rectifier regulator on a 'D'. The warning first appeared on automobiles when alternators (with electronic control) replaced dynamos.
There's only the RR to consider on a 'D' and it's the sort of thing that you can probably get away with 9 times out of ten. Having said that, my 'D' had a lot of welding done here and there by a PO and had a non-functional Rectifier Regulator.
Andy
tommyg
So, would removing the battery connection before welding eliminate that risk?
dbartlett1958
Yes.
JamesBe1
To the point about trickle charging, I've had all my tractors on a trickle charger (mostly) all this past winter. I doubt that I did any harm, and it is far better than letting them sit in the cold and potentially freezing (if the charge drops too low).  We'll see in a few weeks, but I'm pretty confident that they will start up and run just fine.
wheeledhorseman
You're not likely to do any harm James, quite the reverse. Lead acid batteries tend to self discharge and the effect increases with age. So if you fully charge a battery before winter storage, then by spring it will have lost some of its charge even if not connected to anything. If the level of charge falls too much other deterioration of the plates inside will start to occur so overal it's bad news.
Trickle charging is a very good idea (I prefer the term 'maintenance charge') and modern chargers automatically switch to this when the main charge is complete usually indicated by a green LED. The current for a maintenance charge is very small and the voltage used lower than for a normal charge which prevents gassing and therefore loss of electrolyte. Older chargers with an ammeter may appear to drop back to virtually no charge when the battery is fully charged but the voltage remains high causing gassing so these old chargers are not suitable.
Getting back to the thread, the label referred to mentions welding and fast charging. By 'fast charging' it is referring to the big chargers (usually on wheels) used in workshops that can start an automobile with a flat battery or fast charge the battery at currents in the order of 40 amps. The average home charger tends to charge at perhaps 6 amps max, often less, so there is no need to isolate the RR on a 'D' for this.
Andy
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
