Bobie01 22 #1 Posted February 14, 2013 Hello I have last year bought a C-165 in which the engine was broken. Now I have the problem that a KT17's in, but this can not be right. Now something has been exchanged, the engine or the hood. How do I know now if it's a C-165 or C-175 is? because I want to install a K301, which I bought yesterday, it's running great. What I need to change so that it fits? Jeff Share this post Link to post Share on other sites
pfrederi 21,295 #2 Posted February 14, 2013 Is there a data plate anywhere on the machine? The 12 hp K301 should fit easily. If your tractor has the isolation mount for the motor (4 rubber disks) then you will need the correct oil pan on you 301. (Or forget the isolation mount and put the motor directly on the frame) You may need a different hoop for the PTO Share this post Link to post Share on other sites
Bobie01 22 #3 Posted February 14, 2013 I can t read the data plate The engine is from an Wheel, Horse so i think it s the correct oil pan or what is the Problem when it s not the correct one and how it is with the belt guard?? Share this post Link to post Share on other sites
Wheel-N-It 2,978 #4 Posted February 14, 2013 Can yo send some pics of this project? Share this post Link to post Share on other sites
SousaKerry 503 #5 Posted February 15, 2013 C-175 used a different shaker plate and a different belt guard and pto hoop. post some picture of what you have and of the motor you want to put in Share this post Link to post Share on other sites
Bobie01 22 #6 Posted February 16, 2013 I will do it next Week!! Share this post Link to post Share on other sites
