thehorse 221 #1 Posted February 5, 2013 Can anyone give me an idea of what might be causing a loud whine from my manual pto on 416. It gets louder with increased RPM's and happens whether under a load or not. I took the bell off and greased bearings inside and put it back together but helped very little. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted February 5, 2013 What about the outer ball bearing? Did you verify that it actually is the PTO clutch by starting the engine without the pulley installed? Share this post Link to post Share on other sites
KATO 115 #3 Posted February 5, 2013 There is also a sealed bearing where the engagement hoop and shaft attach on the front side of the bell it is likely bad also. i would replace both ,and the inner race. Share this post Link to post Share on other sites
Wheel-N-It 2,978 #4 Posted February 5, 2013 What about the outer ball bearing? Did you verify that it actually is the PTO clutch by starting the engine without the pulley installed? I'm in agreement with TT on this. Take the time to remove the PTO to see if the noise goes away. Share this post Link to post Share on other sites
thehorse 221 #5 Posted February 5, 2013 Probably just a good idea to replace all of them and not have to worry about them for 20 years. I assumed it was the PTO because when it was engaged, the noise increased. Good idea to run without the bell and engaged. If it is bearings.....anyone know where to find them at a reasonable price??? thanks, Len Share this post Link to post Share on other sites
thehorse 221 #6 Posted February 5, 2013 OK found an older thread with info. Gotta love this place! Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #7 Posted February 5, 2013 Make sure you check the drive pulley too. They've been known to loosen and get pushed back against the block face when engaging the PTO. Share this post Link to post Share on other sites
SNYFIX 13 #8 Posted February 7, 2013 Sounds (sic) like the outer bearing. Don't forget to grease (wheel bearing) the inner bearing !! Later they finally came out with a spacer for the drive pulley to prevent the 'slide-in'. Share this post Link to post Share on other sites
BOWTIE 226 #9 Posted February 7, 2013 I HAD ONE WHERE THE OUTER SNAP WAS SPINNING WHEN THE PTO WAS ENGAGED AND LITTLE AFTER. A NEW SNAP RING AND PTO ADJUSTMENT SOLVED THAT PROBLEM. BOWTIE IN OHIO Share this post Link to post Share on other sites
