lowboy 1 #1 Posted February 3, 2013 hello all, new guy from NY here; i recently acquired a charger 10 (model 1-7931) with the tecumsuck hh100 (115095b). the previous owner stopped using it b/c it "smoked and then died one day". the fuel tank was full of diesel fuel, as was the bowl. it is now up and running with little work. anyways, the previous owner was gravity feeding the carb from the fuel tank, and bypassing the mechanical fuel pump. it is not getting enough fuel to run properly, and stalls constantly whenever its not on flat ground; i can see an air bubble in the fuel line. i cant seem to find a repair kit for this fuel pump. it is not a pulse pump, its mechanically driven. i had a walbro fuel pump kit (K1), but the gaskets are wayy too big and not even close to being correct. the gaskets look like the ones show in this thread: , but since i cant see the rest of the pump, i cant be sure. the gasket on mine is almost square. anyone know where i can get a rebuild kit? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted February 3, 2013 :WRS: Unless you're trying to keep things original, I'd think seriously about converting to a modern pulse pump. (like eBay item # 330760329739) You can make a ported block-off plate for the mechanical fuel pump location to "power" the pump. Share this post Link to post Share on other sites
lowboy 1 #3 Posted February 3, 2013 im certainly not going for originality here. so in theory; remove mechanical pump, make block-off plate with a hole in it, stick hose into hole and use it "power" the pulse pump? thats it? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted February 3, 2013 Yes - that's it. This is a "factory" block-off plate for a Kohler: If you make the block-off plate thick enough, you can tap it for a barbed fitting like this: http://www.grainger.com/Grainger/Hose-Barb-6AFH3 1 Share this post Link to post Share on other sites
lowboy 1 #5 Posted February 4, 2013 wow, thats great. thanks for the help. ill swing by napa after work Share this post Link to post Share on other sites
Retired Wrencher 6,371 #6 Posted February 4, 2013 :USA: I hope u enjoy this site. A lot of help here to guide you along. Take care Gary B................... Share this post Link to post Share on other sites
