Markdev6 0 #1 Posted January 29, 2013 Hi I have a c-125 , and it won't engage any gears please help its my first wheelhorse and I am a bit green with them !! Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #2 Posted January 29, 2013 :WRS: Feel free to contribute as much information as you can to help those who might be able to help you. Assuming the engine is running and you have the clutch pedal depressed...... what happens ~ or what do you do next? :confusion-shrug: Share this post Link to post Share on other sites
rmaynard 14,934 #3 Posted January 29, 2013 Do you have the belt cover on? Share this post Link to post Share on other sites
Markdev6 0 #4 Posted January 29, 2013 I have the belt cover on , and with the engine running I clutch select a gear but nothing happens when I try to move !! It's strange though I had driven the tractor stopped to close a gate then got back on the tractor and it wouldn't move when I put it in gear to drive away !! Thanks for the replys Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #5 Posted January 29, 2013 Nothing in high or low range? It may have sheared the key at one of the wheel hubs. Share this post Link to post Share on other sites
Markdev6 0 #6 Posted January 29, 2013 No nothing it won't move at all !! When I put it in gear and de-press the clutch Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #7 Posted January 29, 2013 Did you look at the drive belt to see if it might have broke or came off the pulley? Share this post Link to post Share on other sites
Markdev6 0 #8 Posted January 29, 2013 Yeah the belt is still on and looks fine ! Share this post Link to post Share on other sites
TT-(Moderator) 1,129 #9 Posted January 29, 2013 It may have sheared the key at one of the wheel hubs. Do you know where these are or how to check them? Share this post Link to post Share on other sites
Wheel-N-It 2,967 #10 Posted January 30, 2013 Are you sure the Hi/Low range shifter is firmly seated in high range? Maybe you nudged out of gear by accident. Share this post Link to post Share on other sites
Markdev6 0 #11 Posted January 30, 2013 No I don't know how to check them can you give me info please Share this post Link to post Share on other sites
MalMac 1,328 #12 Posted January 30, 2013 On your Hi-Lo shifter lever the smaller one like stated before make sure it's in Hi or Low range. It's easy to bump getting on or off. Don't force it hard just move it one way or the other to try and get movement. It has to be engaged one way or the other before you can select a gear to move. Share this post Link to post Share on other sites
MalMac 1,328 #13 Posted January 30, 2013 Like TT said you need to check your hubs. Look at the back of the hub to make sure the set screws have not come loose. They are a squared head or sometimes a hex head with a lock nut. Both hubs will have them. If they seem ok go ahead and put the tractor in gear and let out on the clutch and check to see if the axles are spinning inside the hub. Be careful doing this in case the tractor starts to move. If the axles are spinning then you have sheared a key. Share this post Link to post Share on other sites
Don1977 604 #14 Posted January 30, 2013 You could also have broken the key on the transmission drive pulley. Share this post Link to post Share on other sites
truckin88 104 #15 Posted January 30, 2013 Jack up the rear and see if the tires spin in gear or they roll freely. Share this post Link to post Share on other sites
