dbartlett1958 99 #26 Posted January 29, 2013 Hi Duff I'm up in the hills in Stowe. I would be thrilled to have the chance to talk with someone about my new WH. I can tell you this, I had my eye on getting a tractor at the end of the fall, then spent a good chunk of this winter falling in love with Wheel Horses. Our local Toro shop had a few older Horses in their used dept. and after talking with the guys about them, sitting on them and really letting my mind drift with all they are capable of (plus how darn cool they look), I new I had to find one. I found what I was looking for in a 312-8 from way down in Mass and on Sunday spent the day driving to pick it up. I am new to them mechanically (and am not crazy handy with the wrench, though I am eager to learn to do everything to keep this tractor and pass it on to my son one day. The wife is 4 months pregnant with our first!!). I plan on having lots of chores involving the tractor to keep me sane.... Thanks for saying Hi- Indy, These tractors are very simple to own and maintain. They were built to last from quality materials, unlike the Big Box junk you see everywhere these days. All the knowledge and help you will ever need to keep your 312 going is right here. Like Van said above, that tractor will last you the rest of your life if you want it to. 2 Share this post Link to post Share on other sites
dcrage 631 #27 Posted January 29, 2013 Indy Don't be afraid to work on these tractors -- After 20 years of owning my 310-8 I still am learning that these tractors really were designed to be worked on by the owners Your drive belt is under the belt gaurd running along the right side of the tractor, right next to your brake foot -- If you need to replace this it is accessible by removing some of the foot rest and the gaurd; probably easier if you remove the wheel on that side -- You can see the bolts -- If you need to put the spring on the clutch, you will be on the other side -- Again removing the wheel will make things easier Don't be afraid of hurting this tractor -- It really is designed for these things to happen -- Take your time -- Take some pictures as you go if in doubt -- You will be able to do this Share this post Link to post Share on other sites
Indy443 30 #28 Posted January 30, 2013 Indy Don't be afraid to work on these tractors -- After 20 years of owning my 310-8 I still am learning that these tractors really were designed to be worked on by the owners Your drive belt is under the belt gaurd running along the right side of the tractor, right next to your brake foot -- If you need to replace this it is accessible by removing some of the foot rest and the gaurd; probably easier if you remove the wheel on that side -- You can see the bolts -- If you need to put the spring on the clutch, you will be on the other side -- Again removing the wheel will make things easier Don't be afraid of hurting this tractor -- It really is designed for these things to happen -- Take your time -- Take some pictures as you go if in doubt -- You will be able to do this Dcrage, Thank your for your post, I needed that shot of encouragement to crack into this tractor and get to know it. I am truly wishing I had a garage space to work in, but I am preparing to have cold hands this weekend. Worse things have happened. One question I had about the clutch shock. Do I unbolt it and remove it altogether? Or simply replace the stock clutch spring with a stronger spring and that will override the shock? Thanks for the help, suggestions and encouragement to DIY. This place really is great! Share this post Link to post Share on other sites
dbartlett1958 99 #29 Posted January 30, 2013 Indy, I would remove the shock/spring altogether. If left on it could possibly be affected by cold temps and impede the action of the coil spring. JMHO. David Share this post Link to post Share on other sites
rahawk 0 #30 Posted January 23, 2016 Can anyone tell me how to remove the throttle lever knob on a 312-8, It's not obvious to me how it is held onto the lever. Share this post Link to post Share on other sites
Warning:Unsupervised 83 #31 Posted July 4, 2020 On 1/29/2013 at 9:21 PM, dbartlett1958 said: Indy, I would remove the shock/spring altogether. If left on it could possibly be affected by cold temps and impede the action of the coil spring. JMHO. David Yep' I ended up removing my hyd dampener shortly after adding the spring because it still interfered on take off occasionally. Only took a few minutes to remove & toss in the ol' scrap bin. Takes off much better with it off. Share this post Link to post Share on other sites
