tommyg
Custom Weights and Chains for a D
tommyg
After some inspiration from a few members for wheel weights and chains, I decided to put my thinking cap on and design some tire chain tensioners and wheel weights for my D180.
I found some spring type tensioners from a few vendors on ebay, but decided that none of them had enough springs to do an adequate job. After some hunting, I ended up finding some springs at Home Depot, but they ended up being too long. So I cut each of them in half, then heated the end and formed a new loop in which to pass a 1/8" vinyl cable through. Purchased 4 springs for each wheel, which gave me 8 springs per wheel when I was through. Ended up with just the right amount of tension to tighten the springs equally all the way around.
More to follow... Seems I can never add more than 4 pics at a time.
  • Like 3
tommyg
Once that part of the project was complete, I moved on to adding weights to the wheels. Working at the Y in town, I was able to nab a set of 125 York dumbbells that were put away in storage never to be used again. Went to the local surplus store and picked up some square a 1 1/4" square stock and set out to make a fixture that would support the weights. I used the 1" bar from the barbbell set as the center stock piece and welded it all together.
Drilled holes in the fixture and got it mounted to the wheel.
Then all painted up.
tommyg
Next, I went about painting up the weights and got everything mounted.
The end of the barbbell shaft was drilled and tapped for a collar that held the weights on. So I took advantage of this and used it to secure the weights on.
That's all! Just thought I'd share it. Turned out pretty good and added 125 pounds to the rear end of my D.
  • Like 4
"D"- Man
Looks really good, just goes to show where there's a will there's a weight!!! Mark.
KC9KAS
Very nice job with the springs and the weights.
Kelly
Looks very good.
rexman72
very well done
Tankman
Adding this to my famous quotes. Thank you Mark. You will be quoted often. :ychain:
Nice neat job on the D chains 'n weights too!
varosd
using the barbell weights is great and if are plowing and get a notion to do a little......
tommyg
Pretty funny varosd! There's a Planet Fitness right at the end of my street.
1maidenfan
Great job on the weight bracket, looks awesome!!!
I also added weights on my 'D' the same way, works great and much cheaper than buying factory weights.
wheeledhorseman
Neat solutions on both counts - thanks for posting them. :thumbs:
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
