RCTruckDaddy 8 #1 Posted December 29, 2012 I have 1982 Workhorse GT 1142 with the spindles that use a retaining clip to secure the front wheels. Can I swap these out for the older style that use a bolt to hold the front wheel on. I have a 69 Electro parts tractor. Will they work? I lost a wheel plowing on Friday and don't want to experience that again. Thx Dave Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted December 29, 2012 Yes direct bolt on, just check that the flat arm the tie rod bolts to is not bent, they bend when the tire runs in to stuff, a little at a time. I like the bolt on style myself, I've lost a wheel plowing before, and I was at a neighbors house being nice, could not pick the tractor up and put the wheel on by myself, lost the snap ring, had to walk 1/4 mile home get a jack and snap ring walk back and fix it, all while it was snowing hard, after that no more snap rings. Share this post Link to post Share on other sites
roscoemi 245 #3 Posted December 29, 2012 I'm with Kelly on this. Lost the right front wheel twice in 10 feet. Next I lost the clips and went with bolt splindles. Share this post Link to post Share on other sites
RCTruckDaddy 8 #4 Posted December 29, 2012 Thanks guys. Only reason I had clip was I have the plastic caps on the hubs. The clip was in the grease in he cap. I will change them this weekend. Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted December 29, 2012 I have cheated before by drilling a hole right in the clip groove through the spindle and used a cotter pin, some spindles are factory like that also. 2 Share this post Link to post Share on other sites
RCTruckDaddy 8 #6 Posted December 29, 2012 Yeah my father in law has a 310-8 with the spindles drilled. Share this post Link to post Share on other sites
squonk 46,904 #7 Posted December 29, 2012 If I get a parts tractor that has bolt on spindles I save them. Then when I get a tractor I'm going to use I swap them out first thing. Share this post Link to post Share on other sites
