toolmaker40 6 #1 Posted December 24, 2012 i just bought this tractor all the saftey switchs wires were burnt up melted it had all been by passed, any way i am just hooking up the needed wires the touble i am having is where does the purple wire hook up to ? i know the red wires are the oil pressure switch,white is the kill wire but the purple? i have looked at the diagram cant figure it out , i put meter on it no power output? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,847 #2 Posted December 24, 2012 Have you looked at these diagrams? http://www.wheelhorseforum.com/files/file/612-tractor-1987-416-8-31-16k803-wiring-detailedpdf/ Garry Share this post Link to post Share on other sites
toolmaker40 6 #3 Posted December 24, 2012 thanks, yes i have used the diagram to wire it , the white wire on the "M" terminal of the ignition switch, but when i put the purple on the "R" it causes a dead short???? so i have left it off for the time being the lights,gauges work fine with the ignition , ????? thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,847 #4 Posted December 24, 2012 You must be working with a different set of wires than what we see in the diagram. Where does your white wire come from? Where does the purple wire come from? Garry Share this post Link to post Share on other sites
toolmaker40 6 #5 Posted December 25, 2012 it has a white,purple,2 red wires on the motor side of the harness its a kohler 16 magnum 1987 i think thanks for the reply Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,847 #6 Posted December 27, 2012 I think there is a huge mistake on the one-page wiring diagram. The white wire from the voltage regulator on the engine should go to the R terminal on the ignition switch. It is shown on the diagram going to the A or accessories terminal. The dark green should go to the A terminal so these 2 wires got switched. If you are looking at the 4-page detailed wiring the charging circuit is correct - white to the R terminal. The gauge and light circuits show the green wire going to the R terminal also but that is wrong. Should go to the A terminal. The purple wires go from the pto switch to the transmission clutch switch and from the switching relay to the starter solenoid. Garry Share this post Link to post Share on other sites
