fourwheels0 191 #1 Posted December 12, 2012 having an issue with my c-141 14 kohler. would leaving the key on for 4-5hrs without it running mess up a condenser?. under load it bogs down and spits and sputters like crazy after a couple minutes run time at wide open throttle.. if i run it with the throttle at 1/2-3/4 it's fine. it just does it at wide open throttle. it has fresh gas cleaned carb,cleaned both high and low needles,new idle seat and needle,new baffle gasket. new fuel filter and lines cleaned out gas tank new air filter cleaned and checked the points and reset the gap. the reason i ask about the condenser is when i brought it home i noticed the key had been left on when it got loaded up on my trailer. Share this post Link to post Share on other sites
CRE1992 143 #2 Posted December 12, 2012 Sounds like a carb or points issue to me. Could also be a problem with your fuel pump. If the key was left in the on position, with the points closed it could burn the points out so that is another possibility. Points and condensor are like $15. If you have time, adjust the valves, or pulling the head and decarboning it. Also whats the spark plug look like? Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #3 Posted December 12, 2012 Try another ignition coil. Share this post Link to post Share on other sites
fourwheels0 191 #4 Posted December 12, 2012 i got it fixed. i reset the carb settings and plug gap. ran it for 25 minutes and no more issues. i think it was just too lean. Share this post Link to post Share on other sites
Wheel-N-It 2,978 #5 Posted December 13, 2012 Don't worry, its to be expected. Don't be surprised if it happens again. Share this post Link to post Share on other sites
JC 1965 1,549 #6 Posted December 13, 2012 I left the key turned on for a few hours and when I realized what i had done, I started checking it out. The coil was so hot I couldn't touch it. I had to replace the coil and points. Now when I turn the key off, I take it out of the ignition switch and hang it on the parking brake handle. :hide: Share this post Link to post Share on other sites
fourwheels0 191 #7 Posted December 14, 2012 cre1992 $15 for a set of points and condenser?. not around here where i am. they want like $37. i really hate this part of virginia. Share this post Link to post Share on other sites
