tommyg
Rehab-ing a blower
tommyg
I picked up a blower for my d180 a couple weeks ago and set about doing some basic cleanup work only to find out that the previous owner must have hit something with the corner that bent the metal back and kind of creased it in places on the left side of the top scoop. I've bent it back as best I can, but the metal is still dimpled and certainly not as smooth as I would like. My question is... while I'm not a body man, I would suspect that most of you use filler to repair parts of your hoods, fenders, etc to blend any defects. Is it unrealistic to use similar materials and procedures to make repairs to an implement like a snowblower? I'm kind of anal about this stuff and really want restore it to look as straight and smooth as I can. I also thought about grinding off the welds and having a metal shop form me another piece that I can weld back on. I'm all ears if anyone has any thoughts.
AMC RULES
Can we see how bad it is?
:wwp:
tommyg
Here are a couple pics. Kind of hard to tell from this. Depends on how the light's hitting it. You can sure feel it, though. Ideally, I'd like to see if I could smooth it out with some simple auto body tools. But that steel is pretty heavy gauge. And it's not all easily accessible from the back side.
jusjeepn
This type of repair can be done by drilling holes into the sheet metal and using a slide hammer to pull most of the dent, BUT..... It takes a bit of know how to drill in the correct places and how much pressure to use on the slide hammer. Another way is to apply just the right amount of heat but once again, it's an art. Either take it someone or leave it be. The combination of cold weather and vibrations from the blower will crack any filler that is put on too thick or incorrectly.
tommyg
Thanks for the advice. The vibrations from the blower is what I was concerned about. Perhaps taking it to an autobody shop would be a worthwhile option. On the back side, I was considering a well placed Wheelhorse decal to take the edge off the wrinkle.
jusjeepn
There are body men out there that do paintless dent removal BUT... (there's that bad word again), I am not that familiar with this process and do not know the limits when it comes to material thickness. Might be worth checking into. Kelly is a body man by trade, maybe he can shed some light on this.
tommyg
Good idea!
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
