leeave96 496 #1 Posted November 29, 2012 Anyone ever busted an 8 pinion - 8 speed tranny with 1-1/8 inch axles in your Wheelhorse pulling with it? Reason I'm asking is that for whatever reason when I am moldboard plowing with my 314-8, 3rd gear low range is just a tad to slow to "throw" the sod/dirt over and I'm tempted to try some high-range gears to get a better speed/results. I'd hate to damage the tractor moldboard plowing in hi-range 1st gear or better. Thanks! Bill Share this post Link to post Share on other sites
can whlvr 994 #2 Posted November 29, 2012 put her in high range and plow away,they are built to work,just keep the oil clean and full and shes good to go Share this post Link to post Share on other sites
gcole 36 #3 Posted November 30, 2012 On my c-120 I plow hi first with no problems Share this post Link to post Share on other sites
baerpath 517 #4 Posted November 30, 2012 We pull in third high all the time.20+hp @ 4500rpm dump clutch while hooked to a 7000lb transfer sled.running 26-12-12 pulling tires. And yes we have busted them Bottom line plowing in high range ain't gonna hurt it, Share this post Link to post Share on other sites
Tankman 3,528 #5 Posted November 30, 2012 Plowed with some old WH's. Never a tranny problem. I want to add, using 85 w 140 gear lube. :-) Share this post Link to post Share on other sites
leeave96 496 #6 Posted November 30, 2012 We pull in third high all the time.20+hp @ 4500rpm dump clutch while hooked to a 7000lb transfer sled.running 26-12-12 pulling tires. And yes we have busted them Bottom line plowing in high range ain't gonna hurt it, That's a great point - if the pullers aren't routinely breaking the tranny with high hp engines, some moldboard plowing ought not to hurt it either. Thanks!!!!!!! Bill Share this post Link to post Share on other sites
pumper.atv 26 #7 Posted December 2, 2012 i plow with the b100 in high even 3rd high but usually 1high Share this post Link to post Share on other sites
kpinnc 17,038 #8 Posted December 3, 2012 I plow rock-hard red clay in high second with no problems. I've actually used my 310-8 (with the "lighter" 8-speed) more often than the 8-pinion, and never had any problems. Just check all your hub's setscrews to be sure they are tight beforehand. Worst complaint I can say I've ever had was that I smoked an older, worn-out drive belt on occasion. Of course, that was my fault for not setting the plow up correctly. It was cutting too deep and it buried itself, so it was my own fault. Share this post Link to post Share on other sites
