glgrumpy 35 #1 Posted November 24, 2012 Have a few WH, all with the same metal headlight bucket in center of grill and the lenses on outside. Now, have several new or newer parts to make some work. I notice the bases are all pop-riveted in. Hate that! I have removed one, painted, new wires and bulb ends and went to mount it back. Seems there is no indent what so ever to allow screw heads. I haven't tried flat-head yet, but would have to be awful small to really be flush and not sure I like that. Putting on lens and they DO hit the screws. If I was to tighten, sure would be broken. SO, you guys have ideas or am I just gonna have to use pop-rivets again to get clearance? Share this post Link to post Share on other sites
KATO 115 #2 Posted November 24, 2012 I had to use rivets when i did mine too. Share this post Link to post Share on other sites
Sparky-(Admin) 24,646 #3 Posted November 24, 2012 The original wiring and pop rivits lasted for 35+ years right . Fix it right with the rivits and you wont have to deal with it for the next 35+ years. Mike....... 1 Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted November 24, 2012 The rivets only hold it in place till you install the lens, the screws for the lens go through the hood and screw in to the mounting bucket, I use rivets to hold them in till the lens is installed, just like factory. Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted November 24, 2012 I have removed, rewired and painted several of the light buckets....Pop rivet it back into place. Share this post Link to post Share on other sites
ericj 1,579 #6 Posted November 24, 2012 i have used flat head srews on mine when reinstalled. i think if i remmber correctly they are only 6/32 so they are small and don't interfear, just don't over tighten the mounting screws eric j Share this post Link to post Share on other sites
Tankman 3,528 #7 Posted November 24, 2012 Stay with the pop rivets. I wouldn't use screws, they might get loose with hood vibration. If you want screws, try finding some PEM studs, 6-32 should do the trick. Simply put the stud in the clearance hole, nut on the back tight, remove the nut and you're all set to go. These will stay flat, and digging into the hood, stay put. I've used hundreds of PEM studs and nuts (http://www.pemnet.com/fastening_products/studs_and_pins.html). Use stainless steel, very strong hold in the sheetmetal. Nuts work great too (http://www.pemnet.com/fastening_products/nuts_for_sheetmetal.html). Pricing (http://catalog.swaco.com/category/self-clinching-fasteners?). Easy enough. I did have to replace lenses, purchased after market. Not great but look fine on my Raider 12 and '73 "no name" 12 hp automatic. Share this post Link to post Share on other sites
