cheeko914
Tecumseh
cheeko914
Hello all, I'm a recent member to this forum.
Hoping there might be some folks who can provide some advice/suggestions.
I have a 1968 Wheelhorse 10HP, Charger 10, 1-7931, tractor. The power is a Tecumseh, HH100-115095B engine.
I'm from Pa. & inherited this quite a few years ago & mainly use it for winter & snow removal.
Tried to start her up for this up coming season & it simply would not turn over, even with a new battery. A friend/mechanic took a look & it's his opinion the "stator & coil assembly" ohm output is in excess of 400 & greater then it should be.
My delimma is I checked out most of the small engine repair web sites. None of this particular HH100 engine in their data base. Different HH100 series though do show this on their schematic as #254. Scrolling thru their parts list there is no corresponding part number for the assy. though.
I've viewed similar "stator & coil Assy" on ebay but am really not anxious to purchase at $135 by picture alone.
Any suggestions/recommendations would be greatly appreciated.
Sparky
If it wont "turn over" I would not be looking into a stator or coil. Did you try to just hit the starter with 12 volts? Could it be that critters have moved in under the engine tin and clogged the starter/flywheel area with debris like acorns and its all jammed up? I've seen that a few times.
Mike.........
rydogg
I agree with Mike...the engine should turn over even if the stator test out that it is no good.
Kelly
Ya what Mike said, the coil if bad will only not let it start by no spark, is the engine physically not cranking/turning over, or just not starting? I have used solid state coils but they are not cheap, but I can say they are good coming off running engines.
Cole
Mike.........
Follow what Mike said, the starter may have to be rebuilt, you could have a bad ground, or bad ignition switch, try checking for 12v at the starter when you try to crank the engine and keep us updated, at least you've got one of the older ones, so you don't have to worry about relays, I'm not familiar with that model so I don't know if your horse has safety switches or not. I forgot one more thing :WRS:
pfrederi
Pull the spark plug and try to turn the engine by hand. If it moves then try cranking it with the starter (plug still out). Let us know what you have then.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
