kicked by a horse
d 160 pto help!
kicked by a horse
alright dysfunctional crew, i need some help.
My horse came up lame, was not wanting to start. cleaned out the carb and replaced the float, which did the trick, but now the pto will not disengage! upon start up, the pto runs, regardless of the switch position.
The manual says there is no clutch adjustment. So I started taking it apart. I should note this is a little outside my comfort zone as to what exactly I should be looking for. I did check over the wiring and switch and all seems to be ok. Manual also says check the stator, but one of the heads of the screws that holds it on is stripped and I could not remove it and would not be sure what exactly there is to check. i did try and alter the srew to remove it but to no avail, as you can see in the picture, did not want to go any further with it unless i must. I am not sure how to tell if the clutch friction surface is worn or not. Here are some pictures, can anyone comment on them?
post-8427-0-38460800-1353539075_thumb.jppost-8427-0-82810100-1353539096_thumb.jppost-8427-0-85426200-1353539109_thumb.jp
Could it be the brake adjustment? I need to track down a feeler gauge to follow the adjustment procedures and figure out which part is the brake flange and where the shims fit in, the diagram in the manual does not lable the individual parts.
Any words of wisdom would be appreciated.
roscoemi
Heat on that screw can do wonders to break the stailmate.
TT
Is the circuit dead when the switch is turned off? Does the bearing in the pulley side spin freely? (your first picture)
The 'stator' (field coil) is normally either good or bad. (electrically) If you have to remove it, try an impact driver. A little valve lapping/grinding compound on the end of the screwdriver is an old-school trick to keep the screwdriver from slipping.
KC9KAS
31FcT3Y52uL._AA160_.jpg Try this manual inpact driver next time you have a problem screw.
kicked by a horse
I should have thought of applying some heat to that screw. TT i just cheked the bearing, i can hardly turn it by hand, so much so i didnt even realise it was a bearing till you mentioned it. Is that my next item for an ebay search? Not sure what you mean by is the circuit dead
TT
"circuit dead" = make sure that the switch is actually breaking the circuit for the power to the clutch. Sometimes a switch can come apart internally, and - even though it's in the "off" position - still be supplying power to the device.
I'm guessing the bearing is the problem though. If you can get it out of the pulley, you should be able to match it up at a parts store, OPE or farm equipment dealer, etc.
Kelly
If you can't find a bearing get with me, I have a complete PTO off a D-160
kicked by a horse
Thanks for the quick replys, i will take a closer look at the switch but the bearing seems like the issue. Hope i can get this resolved in time to get my snowblower on and tested before it starts snowing!
As a side note, i just made a two year supporter donation, i figure it is the least i can do to support the community that has saved me from having to pay for service to keep my horse in good health!
Trouty56
Sorry Kicked by a Horse (sounds like a name for an Indian....lol), I don't have an electric pto. Looks like these guys have you straight. Best that this happened now than in January......
dbartlett1958
Before trying to press the bearing out, make sure you support the area around the bearing properly. That piece is cast steel and can bend, which will cause the face not to mate with the other half when everything tries to engage.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
