Tankman 3,528 #1 Posted November 21, 2012 Parts diagrams (414 & 416) show valve stems and inner tubes on the rear tires. Never had to replace tires or rims, have a number of spares. Are the rear tires "either or" (tubes or tubeless)? Share this post Link to post Share on other sites
ray 10 #2 Posted November 21, 2012 I've added tubes to stock tubeless tires on garden tractors for years, with good results. Share this post Link to post Share on other sites
bmuone 15 #3 Posted November 21, 2012 I put tubes in mine because they slow leak down and the usual leaking place is around the edge of the rim. Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted November 21, 2012 I too have installed inner-tubes on "tubeless" tires. This is also a good idea if you add fluid to your tires.....no fluid comes in contact with the steel wheel. Share this post Link to post Share on other sites
specialwheelhorse 174 #5 Posted November 21, 2012 One of the first things I do is add tubes all around. Saves the air compressor,Keeps me on an even keel and they all stand tall. Nothing looks worse than a beautiful little red tractor with a flat tire. But with the price of tubes now it's getting harder and harder for me. Jim in Texas Share this post Link to post Share on other sites
Cole 25 #6 Posted November 21, 2012 Yep, I put tubes in mine also, I do it because its so simple. I just takes my tires to my local tire shop and they break the bead for no cost, slide the new tubes in through the sides, fill em' up and your good to go until you get your roof replaced and get a nail in your tire :no: Share this post Link to post Share on other sites
kpinnc 18,916 #7 Posted November 21, 2012 There is the argument that using tubes in the rear will allow the tire to "slip" on the rim, which usually results in the valve stem being stripped off. Personally, I have never had one do it, and the wheels occasionally spin on my tractor pulling a turn plow with no problems. I run 10-15 PSI just to be safe on the rear tires regardless. Share this post Link to post Share on other sites
can whlvr 994 #8 Posted November 23, 2012 ive had one tire with a tube for 20 years no problems Share this post Link to post Share on other sites
pumper.atv 26 #9 Posted November 23, 2012 i have also heard that putting baby powder inside the tire allows the tube to slip in the tire without tearing the tube especially when running low psi offroaders use this trick in their tires Share this post Link to post Share on other sites
welderman85 53 #10 Posted November 24, 2012 i tube my older tires once the check or start to leak. i tube them Share this post Link to post Share on other sites
rick 310 #11 Posted November 24, 2012 I do the same, tube 'em when you have to add air before each use. Or buy new tires! Share this post Link to post Share on other sites
Alan_Heist 7 #12 Posted November 27, 2012 Where is an economical place to get tubes for the rear tires? Seems like most places are getting $38-43 for these... ouch! I'm running 23x10.5-12 Share this post Link to post Share on other sites
Zeek 2,299 #13 Posted November 27, 2012 I do both depending on rim condition. The tractors I have are mostly for show. If the rim edge where the tire sits is smooth and the tire is new, I have never had a leak if the tires are installed properly with lube. They act just like all car tires/wheels that are tubeless However, I just put new set of tires on some older refurbed rims. The rim edge was okay, but the primary problem was the valve stem hole was partially rusted and I knew I probably wouldn't get a good seal and would have a leak point, so I tubed them. Share this post Link to post Share on other sites
Tankman 3,528 #14 Posted November 27, 2012 Where is an economical place to get tubes for the rear tires? Seems like most places are getting $38-43 for these... ouch! I'm running 23x10.5-12 Pricy inner tubes! You might try Miller Tire (http://www.millertire.com/categories/lawn-garden-tires/). 1 Share this post Link to post Share on other sites
GlenPettit 1,719 #15 Posted November 27, 2012 Inner tubes, price: I got a pair of 23x10 tubes & installed for $43 total at Discount Tire, the tubes were only $14 @ last summer. Was very disappointed with the quality of ($15) tubes from TSC, quickly tore up two trying to put them in myself, trying to be very careful at home; the Discount Tire ones were much thicker & better to start. Share this post Link to post Share on other sites
qd-16 15 #16 Posted November 27, 2012 Where is an economical place to get tubes for the rear tires? Seems like most places are getting $38-43 for these... ouch! I'm running 23x10.5-12 Try your local tire store....that's where I got my tubes.....they ordered them for me and came next day. Share this post Link to post Share on other sites
kitkit 142 #17 Posted June 10, 2020 I was wanting to put tubes in a 314-8 rears but the vale stem seems to come out of the rear wheel at an odd angle do you need a special stem . thank you Share this post Link to post Share on other sites
rjg854 13,330 #18 Posted June 10, 2020 Shouldn't need a special tube as far as I know, are you sure you have the tube positioned properly? The stem comes out of the tube at an angle on one side of the tube, so it fits in the rim a certain way. Share this post Link to post Share on other sites
Pullstart 71,161 #19 Posted June 10, 2020 Try inflating the tube outside of the tire and wheel once, to see if/how it’s offset. Install accordingly. Another tip I’ve learned the hard way... you can typically stretch a tube a few sizes up, but never cram an oversized tube into something smaller. The folds and flaps will fail quicker than if the tube were stretched. 1 Share this post Link to post Share on other sites
bottjernat1 2,197 #20 Posted June 10, 2020 I always tube tires. I just bought new shoes for my d-160 and i had all 4 tubed. I always tube tires. My late dad did so i do. 1 Share this post Link to post Share on other sites
Lee1977 7,756 #21 Posted June 10, 2020 Those two ply tires will leak around the rims especially on the front where the tire get some side pressure. I have four ply tires on my tractors. The 400 x 8 triribs have tubes as they atre tube type.on my 312-8. Did I say I hate two ply tires. I had trouble for years with two ply tirrs on my C-120 couldn't keep air in the fronts and I got stuck and ripped a 6" gash in the side of one of the rears. Same with the 312-8 changed out to four ply all around. I put four ply tire all around on the 520-H right after I got it. I went to the local tire store to pick up a tubless tire stem. He gave me one as I didn't have the tire and rim with me and he didn't have to install it. Share this post Link to post Share on other sites
kitkit 142 #22 Posted June 11, 2020 Thanks everyone foe the help , I think the tube had a short stem and the tire slid on the wheel . put another tube in and all is well . Share this post Link to post Share on other sites
