Wheelhorse84 87 #1 Posted November 13, 2012 So my C-160's pto will not disengage. No matter ow must i thread the trunion piece out it stays engaged. Any tips would be appreciated. Thanks in advance. Share this post Link to post Share on other sites
rmaynard 16,589 #2 Posted November 13, 2012 Sounds like you could have something hooked up wrong. The PTO only moves in and out several thousandths of an inch before it hits the brake pad. Could be a weak. broken, or missing helper spring inside the PTO itself. Share this post Link to post Share on other sites
Wheelhorse84 87 #3 Posted November 13, 2012 Could the brake pad need to be adjusted? Share this post Link to post Share on other sites
rmaynard 16,589 #4 Posted November 13, 2012 Sure could. The procedure should be in your owners manual. Share this post Link to post Share on other sites
Don1977 605 #6 Posted November 13, 2012 It could also be the C-clip on the inside has come off the short 3/4" shaft that is attached to the PTO loop. That's what pulls the pulley away from the clutch disk. Share this post Link to post Share on other sites
Wheelhorse84 87 #7 Posted November 14, 2012 If I push the bracket that the threaded rod is attached to all the way forward or as forward as it will go it will disengage. Share this post Link to post Share on other sites
dsholler 54 #8 Posted November 14, 2012 Does it slip when it is engaged? If so, then it is probably the c-clip as mentioned above... I have had trouble with a worn and dirty shaft where the clip popped out of its little groove, so the bracket was for all intents no longer attached to the pulley. The whole thing is not that hard to take apart.. you might just want to do that. Share this post Link to post Share on other sites
Wheelhorse84 87 #9 Posted November 14, 2012 It doesn't slip when engaged. I'm gonna take it apart tomm Share this post Link to post Share on other sites
Wheelhorse84 87 #10 Posted November 27, 2012 So this is what it looks like underneath the PTO pulley on my C1 60. I took the pulley off my b100 and in that threaded hole was some screw with two washers on the end of it in and that one on that tractor works perfect. And my missing the screw at the end of this shaft with the two washers in order to make my pulley go in and out the right way. And also is there spring inside there that goes on the surface of that crankshaft and pushes on the pulley any diagrams or pictures would be appreciated. Share this post Link to post Share on other sites
rmaynard 16,589 #11 Posted November 27, 2012 The B-100 and the C-160 should both have the stud in the end of the crankshaft with two thrust washers and a spring to help push out the PTO bell. If you are missing them, that is your problem. Share this post Link to post Share on other sites
Wheelhorse84 87 #12 Posted November 27, 2012 Great now I know how to fix it Share this post Link to post Share on other sites
Wheelhorse84 87 #13 Posted November 28, 2012 The stud that goes into the crankshaft cost me $33 at my local wheelhorse guy. The little tiny thrust bearing $12. Wow that's expensive. Share this post Link to post Share on other sites
psalms83:18 174 #14 Posted December 18, 2015 Anybody got pics of that spring?? Share this post Link to post Share on other sites
rmaynard 16,589 #15 Posted December 18, 2015 (edited) 52 minutes ago, psalms83:18 said: Anybody got pics of that spring?? It can also be found under the seat on 300 series models. Edited December 18, 2015 by rmaynard 1 Share this post Link to post Share on other sites
