JC 1965 1,548 #1 Posted November 6, 2012 I would like to install two LED flood lights on my C121 in case i have to clean my driveway after dark. The lights are 18 watt with 1350 lumens of output. If i decide to purchase these lights, do i have to wire them any special way ( use a relay ? etc. ) or can i just power them straight from the accessory terminal on the ignition switch. The lights only draw about 1.8 amps each. Also what size fuse should i use ? Any help appreciated. :thumbs2: Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted November 6, 2012 At 3.6 total amps, you can go directly to your accessory terminal. I would fuse it at 10 amps and use 16 gauge wire. Here is a double edge sword........LED lights do not produce very much (if any) heat.....good for the electrical system, BUT.....LED lights won't melt off any snow that accumulates on them.. Share this post Link to post Share on other sites
