1maidenfan
homw made 3-pt A-frame drawbar
1maidenfan
Had been wanting to make one of these for a while now , so...after an hour or so in the barn with the grinder and the welder and this is what I came up with. I believe this will work for what I need to use it for.
"HOME MADE" :banghead: LOL
post-4490-0-61468400-1351969133_thumb.jp
post-4490-0-97836300-1351969145_thumb.jp
KC9KAS
Looks good....What is it going on?
Tap53
Hey, that looks nice, I like clean looking work like that, Good Job, Why are you working in the barn??
You aren't using a straw bale for a welding bench are you?? :happy-bouncyredfire:
Tim
Trouty56
Nice!!! Going on a "D"!!!
1maidenfan
Tim
Thanks. Noooo it's not a bale of straw :ROTF: It's just an old piece of particle board that I use as a mobile bench.
This is to go on my D series tractor(s).
Don1977
Looks good all it needs now is a receiver hitch welded in the center.
KC9KAS
Just bought this from Rural King this morning to do the same thing!002680017_1.jpg
1maidenfan
I have a flat piece of steel that i bolt to it with a hitch ball on it that way I can move my trailers around also. The reason I dont weld it on is that I need the hole to be able to move my smaller trailers and my yard sprayer as they have the hitch type mounts.
I am painting it now and will update with pix later today.
Thanks
glgrumpy
Looks good. I made one like that for my PK's. I used a little heavier stock on top sides, about same width. I also used an angle iron for bottom with flat side turned up and the pins went into the heavier upper stock as it passed over the angle iron ends. Clear as Mudd? Anyway, I put a ball in center for trailers or could use other holes for clevis for chains. With an A-frame the hitch bar won't roll when using it like just a bar does. I do see now many guys just making an attachment that is straight up from bar to 3rd link with a receiver square at the bottom end that keeps from rolling too. Not sure a reciever end is all that much handier myself, but haven't really had one either.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
