1maidenfan 202 #1 Posted October 28, 2012 Ok, here is my way of installing tire chains start by laying out the chain, making sure the cross chain tie links are facing down(see pic 1 ,2 and 3) Set tire on chains(remove air from tire, as much as possible) and wrap chain around tire and loosly attach tighting bar.(see pic # 5) Flip tire over and connect oposite site as tight as possible.(see pic # 6) Now flip tire back over and tighten other side as tight as possible.(pic # 7) Now adjust cross links so they are straight across from each other.(pic #8) Now air up tire and your done, well mount back on tractor, then your done. Pix # 9 and # 10 are of tires mounted with weights(home made brackets) 4 Share this post Link to post Share on other sites
Buckshot 1 15 #2 Posted October 31, 2012 :) I always install my chains with tires mounted on the tractor. Might have to try your way, might be easier way to tighten the chains. :flags-usa: Share this post Link to post Share on other sites
Lars 526 #3 Posted October 31, 2012 ill do it the same way as Maidenfan does it takes about 15-20 mins do do it that way.. when ill have the tire off i also check if the hubs are tight etc. Share this post Link to post Share on other sites
Cole 25 #4 Posted December 10, 2012 I also take them off mine to put on chains, but I've never deflated the tires. I use my craftsman for plowing in the winter, I don't use my restored b-100 because I don't want the rust from the brine and salt, Even though the 10hp Kohler in the horse seems to have more power than a 21hp Briggs twin. Share this post Link to post Share on other sites
Tankman 3,528 #5 Posted December 10, 2012 I leave the tires on the Horse when installing chains. After the chains are on, bungee binders to keep the chains snug. When the snow is dozed, I back into the barn up on 2x6's or larger. Keeps the chains out of the dribbles. I can set the blade down also on the boards. Edge is high 'n dry. 1 Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted December 18, 2012 The bungee chain binders are inexpensive and keep the chains neatly in place. http://www.tractorsupply.com/peerless-rubber-chain-tightener-passenger-1144077 Share this post Link to post Share on other sites
JohnD 145 #7 Posted February 24, 2022 I use the deflate the tire trick. I put a jack under the rear axle so they are easy to rotate and spin the chains on. They latch easily and then when I reinflate the tires the chains get nice and tight. With this technique I was able to do away with the bungee cords that the PO used to keep the chains tight. Share this post Link to post Share on other sites
