rplosnak
Length of C-161 drive belt
rplosnak
Could someone be so kind as to provide the correct drive belt length on a C-161.
Guy I bought it from had installed new belt and said the burning smell was coming from new belt getting worn in??!!. Didn't believe that BS.
I took everything apart to check for rub areas. Finally found belt is jumping off the spring loaded pulley on the engage lever. Thinking new belt is too long? Partstree does not show length.
If I had correct length for part # 7473 I could try new belt from local TS. If not, do the springs weaken and wear out?? Thanks for any help.
CRE1992
Yes, the springs do weaken and wear out. They are not that expensive normally, like $10-15 a spring, however it is possible there are not many NOS springs left. Whenever I get a tractor, I replace the drivebelt, idler pulley, and springs for the idler tension and the brake spring.
-Charles
jeremi3210
I used a 5L84 belt from napa on my c121 auto.
gwest_ca
The original 7473 belt for gear transmissions is HB/5Lx81.95"
Garry
Don1977
If the belt won't stay on the first thing I would check is the idler pulley for bad bearings. The idler bracket should have a 90 degree bend at the top to stop the belt when the clutch is pushed in, it also keep the belt on the idler.
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
