jusjeepn
An RJ Story
jusjeepn
Did some swapping with Jim M awhile back and brought home this RJ. Numbers on the trans indicate it could be a 59 and it also has the solid pan seat. I've just been pushing it around the shop hoping to get some spare time to fix a fuel leak so I can use it around the yard.
Monday afternoon I was messing around with the vert getting it ready to take up to Scott's M&G and decided to mess with the RJ. Fixed the fuel leak and putted around the yard a bit.
Tuesday arrived and I got this brilliant idea to do a 4 day refresh on the RJ and take it to the M&g also. Started tearing it down around 3pm and started acessing the damage. One of the previous owners had done an excellent job of protecting it from rusting, unfortunately for me.
The roll pin in the steering wheel had become part of the wheel so I spent over an hour heating and beating till it finally gave in. Now the wheel was another story. Damage acessment for removing wheel: 1 three jaw puller, a tank of O2 & 2 hours. I finally said to hell with it and cut it off.
Had to go ahead and fix it.
Wed. I got home around 11 and started pressure washing, blasting parts, grinding parts and dipping some in the E-tank. I spent the biggest part of the day with a hammer and dollie in hand doing sheet metal work. This was an all day ordeal so that's all that got done, but when I went to bed it was all ready (except the hood)for paint...or so I thought.
Thurs. dawned bright and early. In the shop by 8. Removed the frt wheels from the E-tank and found one had 8 holes in it. Have you ever tried to weld a soda can? An hour & 1/2 later all the holes are welded up and both sides of the wheel dressed & ready for paint. The hood had the standard cracks from the tank straps plus two of the mounting point were broke out. Back to the welder....
Finally got the hood welded up and and a coat of mud on around 12.
Worked with that until I was happy with it...3 hours later! Started spraying around 3:30 & got half the frame done when one of my daughters shows up to pick up her Blazer I've been storing for her. Of course it wont start, has a flat tire and the radiator is empty. Finally got back to spraying an hour later.
I found a few spots I missed on the hood before spraying it so back to the mud. 9pm finally got it in primer.
Finally got some color on it around 11.
Today I'll reassemble, just in time for the M&G
HorseFixer
WoW, Pat boy Howdy, ya talk about a Whirl Wind Resto :notworthy: It Sounds like you have been burnin the candle at both ends. :eek: She looks great, and yeah anymore I just wack the shaft off that way I can work on the blasted thing easier, and introduce it to Mr. Hydro Press which usually along with the heat you mentioned wins the war, and if that dont work theres always sluggo. :hide:
~Duke
COMMANDO6
Wow! That was fast.
Coadster32
Get-R-Done for sure!!! :handgestures-thumbupright:
Jake Kuhn
Very nice! :handgestures-thumbup: Looking forward to seeing it! ~Jake
AMC RULES
Determination, and perseverance will alway prevail.
Nice work, can't wait to see it all put back together. :popcorn:
stevebo
That is the way to get it done- go hard!
fireman
Wow and I thought I put in a lot of time in the shop! Nice Job!
massey
That's some fast work, looks good so far. :handgestures-thumbupright:
VinsRJ
Nice Job!
I am always amazed by how fast some of you guys run through a project. Mine seem to last forever....
kpinnc
Beatiful work Pat! And quick too!
groundhog47
AGREE and am embarrassed at my pace. Excellent work. Gerry
HorseFixer
By the way! Glad yer getting use of that shop :tools-wrench: you were talkin to me about! :handgestures-thumbupright: Sure is Great havin a nice place to work huh? :USA:
Take care. ~Duke
jusjeepn
Here's a few more in progress...
Decided to go ahead and replace all of the nuts & bolts in the entire tractor so I had to make another run to town.
After many hours and lot's of coffee, I decided I wasn't going to make my deadline so I didn't repaint the rear wheels. Here it is completely assembled.
It's done enough to take to the show. Unfortunately it has developed another fuel leak, this time at the rebuilt carb. I ran it long enough to burn up the fuel in the carb and will just be pushing it around again until I can fix it on Sunday.
  • Like 8
AMC RULES
Well worth the effort, and very nicely done. :thumbs: :thumbs:
Stigian
Nice job Pat, she looks great with new paint. :handgestures-thumbup:
dclarke
Nice work Pat, :thumbs: wish my rj looked that good!
fabricator2009
Well done Pat.
Coadster32
Damn!! Aint no messin around. Glad you're taking it to the show anyhow. :handgestures-thumbupright:
Whmaverick
Wow that was fast, my resto projects take four to six months, but guess that's part of the fun. Keep em comin.
krazy_horse
Great job, I cant even round up the tools I need in four days! krazy_horse
312Hydro
Wow, You made that look easy! Great job on the restore and I know there is a lot of unseen work and knowledge to get it looking that nice that quick! :bow-blue:
