clemedc 29 #1 Posted October 2, 2012 Can anyone tell me if the bearing plate, TIN, rope start and also the recoil start from a K90 will fit on a K91? I have a Wheel Horse K91 missing all the TIN and recoil start, there is a broken bolt hole in the bearing plate and it is the bolt that holds the coil wire up. I know I could have the bolt hole fixed but its prolly cheaper to buy the parts on an old engine. Clem Share this post Link to post Share on other sites
SousaKerry 503 #2 Posted October 2, 2012 Drill the hole out and put a keensert in it. Take about 10 minutes start to finish with a cordless drill even. Share this post Link to post Share on other sites
buckrancher 2,697 #3 Posted October 2, 2012 Can anyone tell me if the bearing plate, TIN, rope start and also the recoil start from a K90 will fit on a K91? I have a Wheel Horse K91 missing all the TIN and recoil start, there is a broken bolt hole in the bearing plate and it is the bolt that holds the coil wire up. I know I could have the bolt hole fixed but its prolly cheaper to buy the parts on an old engine. Clem yes Share this post Link to post Share on other sites
clemedc 29 #4 Posted October 2, 2012 Maybe I didnt make it clear? The spot that the bolt goes into is physically snapped off as in not there. Oh ok thanks Buckrancher Share this post Link to post Share on other sites
SousaKerry 503 #5 Posted October 2, 2012 Oh ok, yes then by all means make the swap..... and I'm not even blonde.... well not since I was 4 anyways Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #6 Posted October 2, 2012 I seem to recall a few variations of bearing plates / magnetos / flywheels, so you'll want to make sure all of those components are compatible with each other. Share this post Link to post Share on other sites
clemedc 29 #7 Posted October 2, 2012 Thanks for the heads up Terry, Ill be sure to look at the bearing plate Clem Share this post Link to post Share on other sites
