perry 82 #1 Posted January 12, 2007 with help from you guys i tryed to adjust my hydro linkage lever today. i got the comsept of how it works now. there is a spring on the bolt but it looks like i am missing the plastic adjuster coller that would hold pressure on the cam plate. let me know if im talkin with a straight head about the coller?. ALSO, on the linkage cover plate there is a slot in the center. whats that for?. and then there is a little silver flat bar that has the top bent over witch is under the plate and conected to the rod that runs the foward-reverse handle. i dont have a clue on what that little bugger is for?....thanks guys Share this post Link to post Share on other sites
Rollerman 291 #2 Posted January 12, 2007 Perry Your descriptions have left me a little confused? I'll see if I can get a parts blowup pic on here or you could send one of your 877? Will try & help best I can. Stephen in northern IN Share this post Link to post Share on other sites
perry 82 #3 Posted January 12, 2007 ill take a pic of what i am talking about. i tryed toro.com but it wouldnt work. Share this post Link to post Share on other sites
perry 82 #4 Posted January 14, 2007 here is the pic of hydro linkage. is this the cam plate & bolt you adjust to hold pressure on the hydro lever. also the spring broke and i cant figure out where it was attached so i just put one on the keep the pedal from dropping. Share this post Link to post Share on other sites
creekside 0 #5 Posted June 27, 2009 I will take pictures of the 875 my brother has. That should be the same. I will try to post something for you tomorow. Share this post Link to post Share on other sites
creekside 0 #6 Posted June 27, 2009 I have the maual for that tractor all scanned in if that would help. If you need better pictures of the manual let me know. But I will still try to get you pictures of the actual linkage in the morning. Share this post Link to post Share on other sites
creekside 0 #7 Posted June 28, 2009 The spring goes from the hole in corner of the cam bracket to a bolt sticking out down and to the right. I had a tought time getting a good picture. I hope this helps. It is a bear to get in there but it will solve the problem greatly. I just did one this spring with my brother. :thumbs2: Share this post Link to post Share on other sites
jusjeepn 59 #8 Posted June 28, 2009 Creekside, check the original post date! I think Perry either parted it out or sold it by now! Share this post Link to post Share on other sites
perry 82 #9 Posted July 13, 2009 Creekside, check the original post date! I think Perry either parted it out or sold it by now! i still have it . i like my little 877 too much to part with it. but i have'nt used it in 2 yrs. it sits in the shed. Share this post Link to post Share on other sites
