Butch 194 #1 Posted September 8, 2012 Lately my C-175A won't go unless I start pushing it first. It won't go forward or backward. I'm worried it may not go even when pushing it. Any ideas? Thanks. Butch Share this post Link to post Share on other sites
Doorvip 1 #2 Posted September 9, 2012 Have you checked your drive belt from the engine to trans ? Share this post Link to post Share on other sites
Agage1 83 #3 Posted September 9, 2012 I have the same problem on one of my c160 s, I gotta push it to get it to go. There is a thread in the transmission forum right now about this problem Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #4 Posted September 9, 2012 Have you checked the woodruff keys at the wheel hubs? Share this post Link to post Share on other sites
kthack657 335 #5 Posted September 9, 2012 Definate;y start with the easy fix...the belt that was the problem I had with my charger 12...took the belt off and there was a huge chunk taken out of it... Share this post Link to post Share on other sites
Butch 194 #6 Posted September 11, 2012 I'll check out the belt and the woodruff keys. Thanks guys. I guess I'm looking for a slipping belt. Share this post Link to post Share on other sites
gomer gump 8 #7 Posted September 14, 2012 check drive belt ,hub keys, hydro fluid too low or overfull hydro linkage out of adjustment / cam plate adjustment, motor bad , unidrive wore out some things to check Share this post Link to post Share on other sites
Agage1 83 #8 Posted September 17, 2012 Mine has been doing the same thing. When I was tinkering with it the other day I noticed the hydro relief valve was slightly open. I tightened it down and it ran fine all day. Don't know if it was coincidence or not, the tractor has it's good days and bad days. Share this post Link to post Share on other sites
