B-8074 20 #1 Posted September 3, 2012 I picked up a 3 gang mower set the other day. The lead mower was locked up so I tore it apart and the small gear on the reel shaft was broke. That took care of that problem. But only one out of the 3 cuts good. Two of the mowers are know missing one the the gears on the reel. Does anyone know who made these and where I might be able to get parts? The only numbers I found are SP 279 which is on the front mower and SP 278 are on the other 2. I did see WH 213 on the inside of one of the wheels. Any help would be great. I can get more pics. Share this post Link to post Share on other sites
gomer gump 8 #2 Posted September 3, 2012 i remember seeing something similar to this at sear,s and wards when i was a kid in the 60, s don,t think wheel horse made this but possible Share this post Link to post Share on other sites
AMC RULES 37,260 #3 Posted September 3, 2012 That one doesn't look anything like my reel mower, but mine is a front mounted unit...so...it's hard tellin' not knowin'. 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted September 3, 2012 Well, Home Depot has one called a SP-501 ProMow Sports Field 5-Gang Pull-Behind Reel Mower7, and a SP-701 that is a ProMow Sports Field 7-Gang mower.......Maybe a ProMow????? Share this post Link to post Share on other sites
Anglo Traction 761 #5 Posted September 3, 2012 On the back of KC9KAS's possible suggestion of it being a Promow, I found this IPL that may help you to I.D yours. http://promow.com/support/diagrams_pro_series.htm Share this post Link to post Share on other sites
B-8074 20 #7 Posted September 5, 2012 Thanks guys. They are definitely Roxy - Bonnar. I emailed them and they responded right back. I have been emailing back and forth and should be able to get what I need to get them back in good working order. Here's a couple more pics. Share this post Link to post Share on other sites
