krazy_horse 59 #1 Posted August 19, 2012 All I can find is an owners manual...so I think to get a good clutch feel I will have to install a new drive belt. Is this correct? The clutch pedel goes all the way foward. If I do need a belt can you tell me the toro or NAPA number? Thanks as allways, Jim Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted August 19, 2012 The drive belt is Toro/WH #7473 and that is the belt I recommend using. Aftermarket belts can sometimes cause issues with grabbing, improper declutching/gear grinding, etc. If there isn't any obvious problems with the mechanical linkage, the belt is probably the culprit. Share this post Link to post Share on other sites
