Fast N Red 5 #1 Posted August 15, 2012 Hi i have a c-120 hydro that i made into a puller recently at my last pull i had very little wheel speed going forward so i pulled and barely moved the sled so afterwords i went into the parking lot and went forwards(slower than normal) then reverse was stupid fast i never messed with any of the linkage is there any thing i can do? And is there any way to get it to build more pressure? thank you Fast N Red Share this post Link to post Share on other sites
Jim_M 179 #2 Posted August 15, 2012 Hydros don't make good pullers. I would look for an 8 pinion 8 speed and make the swap. Share this post Link to post Share on other sites
Fast N Red 5 #3 Posted August 15, 2012 Hydros don't make good pullers. I would look for an 8 pinion 8 speed and make the swap. i know they dont make the best pullers but mine works ive pulled 5 times this year but i am looking for a 8speed but no one has them Share this post Link to post Share on other sites
can whlvr 994 #4 Posted August 18, 2012 check to see if the linkage where it moves the plastic plate is all working,ive had that happen and it was the ball that slides in the plastic plate,ive also had to replace the plastic cam plate Share this post Link to post Share on other sites
Fast N Red 5 #5 Posted August 19, 2012 check to see if the linkage where it moves the plastic plate is all working,ive had that happen and it was the ball that slides in the plastic plate,ive also had to replace the plastic cam plate i checked it the plastic plate was broke on the left side so it leaned to the reverse side but its getting a 8 speed soon so im not worried Share this post Link to post Share on other sites
Trouty56 568 #6 Posted August 19, 2012 Fast and Red.....what are you going to do with the auto tranny? Share this post Link to post Share on other sites
Fast N Red 5 #7 Posted August 19, 2012 Its for sale. Every thing is good but that plastic place. Linkage and every thing related is n cluded Share this post Link to post Share on other sites
Fast N Red 5 #8 Posted August 20, 2012 Fast and Red.....what are you going to do with the auto tranny? Its for sale. Every thing is good but that plastic place. Linkage and every thing related is n cluded Share this post Link to post Share on other sites
Trouty56 568 #9 Posted August 21, 2012 Well I'm glad you aren't throwing it away. Sounds like it is a good unit. I'm sure you will find a buyer in your region. Share this post Link to post Share on other sites
