Trouty56
D series snow thrower
Trouty56
I have a new to me snow thrower for the 180. There is a small gearbox at the drive pulley to change the rotation 90o. I wanted to check to see if it needed gear oil but when I opened the fill hole it was full of grease instead of oil. Which is correct??
1maidenfan
I thought I was going to be able to answer your question as I pulled out my binder with my manuals but my snow thrower manuals say nothing as to what fluid goes into the gear box?
I would say gear lube but thats only a guess.
Will be watching this post as I also will be working on my snow thrower before to long.
Trouty56
I got an answer for this from a reliable source (Tap53) and the box is filled with grease. Tim suggests synthetic because of the cold working conditions. I hope this helps.
sent via mobile....
1maidenfan
sent via mobile....
Thanks for the update, I would have guessed lube for sure.
tommyg
Interesting. I would have guessed oil as well. Good info to have for the d thrower I hope to have some day.
gwest_ca
The 1973-74 manual for the 6-7451 on page 5 says to fill the gearbox with all purpose grease.
Garry
1maidenfan
I'll be, it sure does.
Thank you.
slufoot733
Mine is full of grease, When I opened it to check I used a a wooden paint stirrer to stir the grease and spread it over the gears....just to be sure. But it is a thick grease, not gear lub.
1maidenfan
Yes it is regular grease.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
