Lars 526 #1 Posted August 11, 2012 Well i have a k 91 thats goes in my 551... the engine fires easy up and idels good.. no noise etc ..runs very good on idel, but when i try to rev it up it gets to much gas. (black smoke) and runs bad. and if i adjust it so it runs good when ill rev it up it wont run good on idel... any ideas on what it could be.. i have cleand the carb and all the parts inside it etc etc.. but it has a clinton carb on it. and i ont know if that is right for it.. Thanks Lars.. Share this post Link to post Share on other sites
Lars 526 #2 Posted August 11, 2012 :eek: :eusa-think: Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #3 Posted August 11, 2012 Not saying that it isn't carb related, but have you tried changing the ignition timing? I have one here that won't run right unless the points are closed up to around .014" Share this post Link to post Share on other sites
Lars 526 #4 Posted August 11, 2012 Hmm Thanks TT.. Will give it a try tomm and see if it helps.. Share this post Link to post Share on other sites
buckrancher 2,697 #5 Posted August 12, 2012 sounds like the rod inside the slow speed jet is gummed up if you disassembe the carb and shake it up and down you should hear the rod clunking up and down next to the main jet venturi tube if not the tube the rod is in is gummed up and you will need too pull the brass soft plugs to push out the rod and clean the tube and orfaces by soaking the carb in some carb cleaner and blowing all passage ways out with air Brian Share this post Link to post Share on other sites
VinsRJ 724 #6 Posted August 12, 2012 Just to let you know, your carb is a LMG Walbro off a Clinton not a Kohler. Your K91 should have had a Carter N. Not saying that its the cause of your issue but if its not a properly sized carb its not helping the situation. Share this post Link to post Share on other sites
buckrancher 2,697 #7 Posted August 12, 2012 if you do replace the carb to a carter N you will need a model #18 brian Share this post Link to post Share on other sites
Fordiesel69 274 #8 Posted August 12, 2012 The symptom sounds like a carb issue rather than timing. You will want the correct carb on there anyways. Share this post Link to post Share on other sites
AMC RULES 37,260 #9 Posted August 12, 2012 There's a couple of the Carters on Ebay now Lars. http://www.ebay.com/sch/i.html?_sacat=0&_nkw=carter+model+n+carburetor Share this post Link to post Share on other sites
Lars 526 #10 Posted August 12, 2012 Thanks guys... have cheked the timing and adjust it a bit but it dint help.. so im starting to belive it must be somthing whit the carb.. so ill think ill need to get me another carb to it.. will look at those Amc put up.. but i dont have any experience whit those old. because ill never seen one so i dont know if any of them are right.. Will a carb from a K161 fit on it or? what engines use the same carb? all help i can get is welcome.. Thanks so far guys.. Lars Share this post Link to post Share on other sites
buckrancher 2,697 #11 Posted August 12, 2012 Thanks guys... have cheked the timing and adjust it a bit but it dint help.. so im starting to belive it must be somthing whit the carb.. so ill think ill need to get me another carb to it.. will look at those Amc put up.. but i dont have any experience whit those old. because ill never seen one so i dont know if any of them are right.. Will a carb from a K161 fit on it or? what engines use the same carb? all help i can get is welcome.. Thanks so far guys.. Lars K161 uses a #22 carter N go to charlie's form to see rebuilding an clinton carb http://clintongas.18.forumer.com/index.php?showtopic=266 brian Share this post Link to post Share on other sites
Lars 526 #12 Posted August 12, 2012 Thanks Brian But will this carb work good on my K91? i had it going a bit better now when it idel it get a bit rich food a bit black smoke.. and it rev up better then before.. i had the carb in pices again but could find any thats seems to be wrong. cleand it up whit carb cleaner and air... Lars Share this post Link to post Share on other sites
buckrancher 2,697 #13 Posted August 13, 2012 it should most clinton carbs (Lmg / Lmb ) type were used on small bore engines there should be a number on the side of the carb like (Lmg #117 ) when you had the carb apart did you shake it next to your ear and see if you could hear the little rod clunking back and forth Brian Share this post Link to post Share on other sites
Lars 526 #14 Posted August 13, 2012 it should most clinton carbs (Lmg / Lmb ) type were used on small bore engines there should be a number on the side of the carb like (Lmg #117 ) when you had the carb apart did you shake it next to your ear and see if you could hear the little rod clunking back and forth Brian yes it did but it was hard to hear,, i think this carb has on one side it is #77 and the other side is #49 on it.. if u click on the pict in this thred u got big pict of it.. Lars Share this post Link to post Share on other sites
