1054josh 25 #1 Posted August 10, 2012 Exactly what holds the grill on these tractors. One of mine has a fender washer with 1/4 nut and the other one has a piece of flat stock with a hole drilled in it and then a lock washer and a nut thanks josh Share this post Link to post Share on other sites
Lane Ranger 11,980 #2 Posted August 10, 2012 A washer on the inside of the grill and a1/4 inch bolt and nut should do the job. The grill usually just needs a "tweaking" of the opening at the spot the hold is in the cowling/front cast housing. Here are the specs on the grill size: http://s728.photobuc...=scan0001-2.jpg Share this post Link to post Share on other sites
855ownerJoel 32 #3 Posted October 25, 2012 My 1054 has a Ubolt on each side and nylon lock bolts. Share this post Link to post Share on other sites
