COMMANDO1
SIMPLICITY CONQUEST
COMMANDO1
when tractor gets hot hydro rear end slows down? bad trans? fluid change? 1000 hours
smoreau
edit
perry
it may have a sealed trans in it. check the fluid level thru the air vent oil. if low, add more thru the vent hole. it can take a long time to get fluid in do to air restriction. i did that to a 1995 model simplicity broadmoor and worked great. sad thing is it had same trans as a craftsman. if your conquest has the tuff-tork K-66 trans in it. see if this helps - http://www.mytractorforum.com/showthread.php?t=212341
