Hodge71 691 #1 Posted July 31, 2012 I have been pondering the next project around here now that the 18 Auto is pretty well completed. I was wondering if it would be possible to take tranny out of the 401, 551, or one of the RJs and swapping in a later model 8 speed. Can anyone point me in the right direction as to what trannys might fit and the feasability of this swap working out. Also which one of the 4 it would make most sense to do this on. I dont know much about these lil guys but I thought it would be pretty cool to make a hot rod with 8 speeds and some other ideas to be named later. I wont be carving up any sheetmetal or damaging anything that cant be put back to 100% stock. Strictly swapping out tires/wheels, paint maybe some wheelie bars and other easily reversible things. Thanks in advance guys Share this post Link to post Share on other sites
wallfish 19,079 #2 Posted July 31, 2012 The only little roundhood that will work without modification is a 551. The others use a 3 piece trans that bolts to the frame differently. Any of the 8 speed trannies will bolt on Share this post Link to post Share on other sites
stevasaurus 23,568 #3 Posted July 31, 2012 Walfish is right to a point. Not positive, but I think the 8 speed transmissions that have the 1 1/8" axles may have a different bolt pattern for bolting on the frame that you are talking about...(551). Some modifications in the linkage to make the brakes work may also be necessary. A 1" axle transmission, 8 speed with the brake band coming off in the same direction of the 5007 trans that you have on the 551 may be a direct bolt on. These are the things you will have to look at to see if it is a direct bolt on. We want pictures. Like John said, the RJs and the 401 is a completely different mounting system, and would take some major welding and fabrication to work. Share this post Link to post Share on other sites
Hodge71 691 #4 Posted July 31, 2012 Of course it has to be that damn 551 with the Lauson that I cant get running....lmao....Just my luck...Well I guess first priority is to get a reliable running machine so that this thing can be enjoyable. I guess I cant pull that engine and replace it with a Kohler can I? Share this post Link to post Share on other sites
Jake Kuhn 1,598 #5 Posted August 1, 2012 I'm pretty sure you can put a kohler on a 551 I don't know if you have to change anything on it,but lars(knusern) is using a kohler k91 for his 551 project. Jake Share this post Link to post Share on other sites
smoreau 658 #6 Posted August 1, 2012 Yank the indian techy and put a Kohler in it!! Best thing you could do to it!! Share this post Link to post Share on other sites
Hodge71 691 #7 Posted August 1, 2012 Awesome...all I gotta do now is find a good 6 or so hp Kohler in good shape!!!! Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted August 1, 2012 Jon Bell did one not long ago but the pictures seem to be lost: Share this post Link to post Share on other sites
Hodge71 691 #9 Posted August 1, 2012 Thank you so much Terry. I thought I was delving into new territory here but alas I'm second in line....I sourced a brand new Kohler Courage horizontal 6.5 HP for $159. Didnt pull the trigger yet but I thought it would make a good powerplant for it because I'm having issues sourcing a K series from back in that era. I really wish there was a way yo ressurect those pics from Jon's post, I bet they have a ton of valuable info for me..... Share this post Link to post Share on other sites
stevasaurus 23,568 #10 Posted August 2, 2012 hodge, you may try to PM Bell, he is still active...he may be able to e-mail you the pictures. :) Share this post Link to post Share on other sites
