Johnm1226
1988 520h
Johnm1226
I have a 520h that after 15 minutes of cutting grass revs very high and noticed also that the vacuume gauge jumps up and down. It does not hold steady? Anyone know what the problem could be? Seems to run fine when cold.
CRE1992
Sir you probably have a dirty carb as the culprit. Try adding some choke, if the engine smooths out take your carb off and soak it.
Sparky
I've only owned one 520 and the vacuum gage was the jumpiest thing ever.....totally unreadable.
Mike............
tiggercl
Mike............
I experienced the same 'pulsing' when I replaced a vacuum gauge on a 520H. The solution was to add or squash more padding (or felt?) on the input side of the gauge where pipe connects. I recall just adding the packing from the old vacuum gauge into the new one essentially doubling up .... settled it down beautifully...
Paul
Johnm1226
Thanks for your advise. I soaked the carb for 1 week and put it back together...same issue. I discovered that the problem turned out to be the gaskets to the Air Intake were in bad need of replacement. Evidentally i think too much air was being sucked in causing it to run like crap. I replaced the gaskets and it runs like a brand new machine.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
