Operator
Three point mower
Operator
OK guys I have a three point rear mower off my D that I use on my C-195 but I need a new belt on the drive in deck. NLA on the right one, anyone else have to replace theirs? I don't like spending $25.00 on belts that aren't the right length and not being able to return them after getting dirty. I'm up to a B-138 but that is still too short.
Suggestions ?
Randy
pfrederi
What model is your deck? The parts listing for my 5-0900 60" 3 pt mower call for a belt #103236 still availble from Toro for only $130 (or more depending on source).
These decks were made by Woods based on their popular and widely used L59 series ( I have one of those as a belly mount for my Case Tractor.) The spindles bearings and seals are all availible from Woods and Woods part number cross to CR/ Timken etc. for much less $$$.
The belt you need is a Woods 24004 (that is on mine now). After market belts can be had for around $20-30. The descriptions vary bu tehy seem to be about 133-135" one spource says B-132 wquivilent. Are you sure you have your routing correct? There is a fair amount of tension adjustment possible.
Operator
Thanks Paul! I don't know model no. no tag. The routing is very twisted up isn't it? I'll check my sources for those belt numbers , I went to our local parts supplier here.
I tought of drilling a new closer hole on the one idler pulley, or putting a smalleer pulley on take up pulley which I have shortened up all the way.
I'll see what I can come up with, thanks
Randy
pfrederi
Maybe this will help....do you have the manual? I have a lot of the woods equivalent part numbers for spindle bearing seals etc.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
