Staub'sLawnmower 11 #1 Posted July 20, 2012 My 520-H dose not move very fast. We bought it new in 1990. Do you think the 520-HC gear set would make a difference? Trying to find one but haven't much luck! Thanks, will Share this post Link to post Share on other sites
varosd 1,185 #2 Posted July 20, 2012 The manual for the 500 series does show that the 520-HC had a faster foward and reverse compared to the 520-H id the present tranny with new oil and filter? Share this post Link to post Share on other sites
Staub'sLawnmower 11 #3 Posted July 20, 2012 Well, actually the hyro runs pretty well. It does not slip when going up hills. Just wish it would go a little faster. Share this post Link to post Share on other sites
zieg72 209 #4 Posted July 21, 2012 Well, actually the hyro runs pretty well. It does not slip when going up hills. Just wish it would go a little faster. Join the club, me too!!! Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted July 22, 2012 Try looking at the gearing in the C series tractors that had the Eatons in them, they may have a better gear, they started using the eaton in about 81, like the C-175, ect...... Share this post Link to post Share on other sites
Staub'sLawnmower 11 #6 Posted July 23, 2012 Thanks a lot Kelly! Looks like all I need is the 22 tooth # 108358 and 44 tooth #101626. The 44 tooth gear looks like it is still available through toro but the 22 tooth is no longer available !!! Will Share this post Link to post Share on other sites
Kelly 1,038 #7 Posted July 23, 2012 Do you have a list of tractors that used those gears?? Share this post Link to post Share on other sites
Staub'sLawnmower 11 #8 Posted July 23, 2012 I will look into that tonight! Thanks- will Share this post Link to post Share on other sites
Staub'sLawnmower 11 #9 Posted July 23, 2012 Looks like all C-125's to the C-175's. Also the 417 and 420 series. I guess everything with the eaton model 11 trans. It looks like they changed when thay built the 518 and the 520. The C-195 has a different gear set (due to the larger wheels?) thanks Will Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #10 Posted July 24, 2012 Don't forget the WorkHorse GT-1800/1848 models. 26" tall tires will get you some speed too. 1 Share this post Link to post Share on other sites
sdgmc05 0 #11 Posted August 1, 2012 All 520h models have a maximum ground speed of 5.6 mph in foward. Share this post Link to post Share on other sites
AMC RULES 37,259 #12 Posted August 1, 2012 Section 4, page 7 of the '88 500 series parts and service manual. Share this post Link to post Share on other sites
smoreau 658 #13 Posted August 1, 2012 417a 1985 has a faster gear then the 86 417a. I have both I will post pics of the difference tonight when I get home, they are on laptop Share this post Link to post Share on other sites
JackC 619 #14 Posted August 1, 2012 For the 1989 model year, the 520HC was rated at 7.50 mph compared to 6.4 mph for the 520H. The "C" stands for Commercial so maybe they made the 520HC go faster for the people mowing for a living? The 724-Z was only a little faster at 8.0 mph. My 1989 520HC fells like if flies compared to my 1994 416H and my 1996 314H that are both rated at 5.6mph and same as the 520H. The 520HC is not quite as fancy but it will out run any 520H. Here is my 520HC: Share this post Link to post Share on other sites
smoreau 658 #15 Posted August 2, 2012 Ok here is what I know on this issue. the early eaton 1100 that came in the c125-175 black hoods to 85 417A's all had the faster trans. 86 and newer was hit and mis. some of the 520's went faster then others. My 90 flys! my 96 came with the slower gears and they got changed with the gears out of a c125 black hood. I took some pics and here they are. there is more then 2 gears that are different. Share this post Link to post Share on other sites
diamondred 63 #16 Posted February 8, 2015 Bravo... good to know... Share this post Link to post Share on other sites
JackC 619 #17 Posted February 8, 2015 Linkage issues can prevent a tractor from reaching its top speed. Has anyone tried to check their top speed with a GPS? My GPS does report vehicle speed, it knows the speed limits and it keeps me from getting a ticket at least so far. I have not used my GPS to measure tractor top speed but it seems like it could be used to do so. Even the slower 520Hs should be fast enough for most applications if the linkage is properly adjusted. 1 Share this post Link to post Share on other sites
diamondred 63 #18 Posted February 10, 2015 I think the slower of the two is going to have more torque, and less pressure on the pump. You can always speed up the input shaft to get your speed. The Faster of the two would have the speed needed mowing. All depends on what you want. Share this post Link to post Share on other sites
bmsgaffer 2,071 #19 Posted February 10, 2015 I think the slower of the two is going to have more torque, and less pressure on the pump. You can always speed up the input shaft to get your speed. The Faster of the two would have the speed needed mowing. All depends on what you want. You shouldn't increase the input shaft speed on hydros. They are designed for a certain max pump speed (for oil pressure, cooling, volume, etc) and going over that can accelerate wear exponentially. Share this post Link to post Share on other sites
