smoreau
66 Lawn ranger tire help!!
smoreau
:confusion-helpsos: I'm trying to get Gabbys Lawn Ranger ready for the Charlotte show and I want to buy some new tires front and rear. Ags in back and 3 rib in front. Rears will be 18x9.50-8's and I need to figure out what size for the front. The options are 1 of these 3 tires. 3.00-4, 3.50-4, and 4.00-4. They will be tubed as they are split rims. Has any one put 3 ribs on a lawn ranger? pics are good for comparison. hear is the tractor before the tare down.
So any help would be appreciated!
sorekiwi
I'll get back to you on the size in a couple of minutes.
Kelly
My fronts are one size smaller than Mikes, the rears I think are 20x9.5x8 I had to raise the fender about 1/4" if I remember right.
I can check sizes if you want, I know the front tires are not cheap.
sorekiwi
Yeah, I remember that Kelly got the smaller size about the same time as I got mine. Mine are the Vredestein V-60's 4.00-4. I mainly wanted as much sidewall as I could get on the little tire.
I got mine from here: http://www.tiresfromeurope.com/products/V60.asp
smoreau
I will be ordering these tires tomorrow night and both above tractors look very nice and thank you for posting. the sizes would be helpful if you don't mind. And thank you very much! Gabby likes the ones on Kellys so I'm thinking the 3.50-4 3 ribs
Kelly
Scott I'm settled in for the night, send me a PM I will look after work tomorrow, but I'm pretty sure the fronts are 3.50x4
smoreau
That's fine Kelly, I settled in about a hour ago LOL The show is sneaking up on me! and I still have to get one tractor down from its winter storage space 10' up on a shelf. And one to finish painting. The truck needs exhaust fixed, and Gabby wants to go visit her mom in NC. I just hope I get it all done in time.
ol550
overstockwheels.com has some ribbed tires that don't look too bad for the price
They just not tri-ribs though. :dunno: Mike
smoreau
:banghead: :no: Miller tire is out of stock on 3.50-4 try rib tires, but they have them on evil bay with tubes for $80 + shipping. I will call in the morning, They are open but Bev is not in tell mon. I did order the rear ags from work at $56 each + tax. Cheaper then any one else and no shipping.
Terry M
I like those front tri-ribs on those rangers and I'd like to find some ag tires the same size for my sons tractor.
I also like that Modified foot control and the running boards for gabby's lawn ranger. :thumbs: I might copy that Idea if you don't mind. :)
post-5864-0-17897000-1342230959_thumb.jp
smoreau
That's fine, if you want sizes for the running boards or anything else just send me a pm. I copied a buddy of mines ranger that he built for his son.
Terry M
Thanks, Maybe I can check it out in person. I'm planning to be at the Charlotte show on saturday and then maybe I could take a closer look at your lawn ranger.(?) I think your set-up is a good idea as I will be worried a little about my sons feet near those rear tires when I get the lawn ranger running.
Thanks again.
smoreau
Look forward to seeing you there! Bring your boy and he can take a test drive!
bran1har
I found a place to buy these front tires. Go down to harbor freight and buy the 10in tire for $5.99. No joke, keep reading. Then separate the rim it comes with and put the tire onto your rim. It is a tad skinier, but work fine and looks good too. Best part is $12 for a pair of fronts! I did it to my ranger and it works nice. Only thing is that the tube doesn't have a bent valve stem so you need to re drill a valve stem hole farther up towards the rim of the wheel.
FreddieFarmall
Just a suggestion-when you take those front tires off don't damage/throw out. They look pretty good, and there are no current tires that match that tread pattern. There are tires with that style lug, but the lugs are smaller. If you don't want them, put on the classified section-I'm sure there is someone on here that does (me!)
Fred P.
bran1har
Keep in mind, I changed them for a reason. The right one's sidewall got torn or something and you can see the tube through it. The left on is ok though. And also keep in mind, those are originals and are 45 years old!, im not too sure if they are that desirable, but I did keep them both.
gtofani
Thanks for all the info,
