horsecrazy red
Fan Belt for D250
horsecrazy red
Hi,
I posted this under the Engines forum, but I'm getting desparate so I thought I'd post it here too.
I need to replace the fan belt on my WH D250 but having a difficult time trying to find a replacement. The one taken off measures 3/8" x 47", but it's very old, cracked, and glazed, so measurements aren't exact. Might be metric, too, in which case the width would be 10mm or 11mm. It also needs to be a power drive rated belt.
Any suggestions as to where I can find one?
Thank you!
clintonnut
Tractor supply has a 3/8" belt. I used the 3/8" belt on the D250 I had.
Charlie
gwest_ca
The belts listed for the D-250 are contradictory and confusing. This is 47"
251030 WH nla Use 252370 nla [3/8"x47"]
6747 Gates 3/8"x47"
3L470W Napa 3/8"x47"
Garry
4xfourfun
If you have trouble locating one let me know. I have a box of new D250 parts in the shop and I believe there are a couple small belts in there that may be correct. Send me a message with contact info and I can check.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
